<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC Plus 2 Official Arduino Samples Not Working (SOLVED)]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I tried flashing the stick with M5Burner using some custom images for this device, and it works correctly. However, if I try (with the Arduino IDE 2.3.2) to upload any example from the official repository, for example: <a href="https://github.com/m5stack/M5StickCPlus2/blob/master/examples/Basic/display/display.ino" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5StickCPlus2/blob/master/examples/Basic/display/display.ino</a>, even though the code is uploaded successfully, the device does not boot. I followed the steps indicated here <a href="https://docs.m5stack.com/en/quick_start/m5stickc_plus2/arduino" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/quick_start/m5stickc_plus2/arduino</a> correctly and I have a good understanding of the Arduino IDE. I also tried recharging the stick, thinking it might be a battery issue.</p>
<p dir="auto">What am I doing wrong?</p>
<p dir="auto">Thank you</p>
<p dir="auto"><strong>Update</strong>:</p>
<p dir="auto">Hello everyone,</p>
<p dir="auto">I am writing just to inform you that I have resolved the issue (by contacting support) and updating to the new library M5GFX (<a href="https://github.com/m5stack/M5GFX" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5GFX</a>) released a few days ago.</p>
<p dir="auto">I hope it is helpful to others!</p>
]]></description><link>https://community.m5stack.com/topic/6216/m5stickc-plus-2-official-arduino-samples-not-working-solved</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:52:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6216.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Mar 2024 09:37:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC Plus 2 Official Arduino Samples Not Working (SOLVED) on Fri, 15 Mar 2024 12:22:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robski" aria-label="Profile: robski">@<bdi>robski</bdi></a> said in <a href="/post/24398">M5StickC Plus 2 Official Arduino Samples Not Working</a>:</p>
<p dir="auto">does your stick loads ok with latest M5Burner firmware? Is user demo from M5Burner works? I can confirm that arduino M5stickCplus2 examples do work as had them in recently. Display, IR, Rtc, Battery, IMU,  I've used Arduino 2.3.2, be sure you  pick M5Stick Plus2</p>
<p dir="auto">The two official images "M5stickCplus2 UserDemo V.0.1" and "UIFlow_StickC_Plus2 V.1.13.2" work correctly. I have also tried other custom images dedicated to the Plus 2, but the only one that boots correctly is Marauder.</p>
<p dir="auto">All sketches executed from Arduino 2 do not boot, and the screen does not turn on. I suspected some power management issue or something related to the LED, but I cannot explain why the demo is working in that case.</p>
<p dir="auto">I downloaded the latest M5Burner tool. What you mean with M5Burner firmware?</p>
]]></description><link>https://community.m5stack.com/post/24400</link><guid isPermaLink="true">https://community.m5stack.com/post/24400</guid><dc:creator><![CDATA[boredtechy]]></dc:creator><pubDate>Fri, 15 Mar 2024 12:22:55 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC Plus 2 Official Arduino Samples Not Working (SOLVED) on Fri, 15 Mar 2024 10:30:51 GMT]]></title><description><![CDATA[<p dir="auto">does your stick loads ok with latest M5Burner firmware? Is user demo from M5Burner works? I can confirm that arduino M5stickCplus2 examples do work as had them in recently. Display, IR, Rtc, Battery, IMU,  I've used Arduino 2.3.2, be sure you  pick M5Stick Plus2</p>
]]></description><link>https://community.m5stack.com/post/24398</link><guid isPermaLink="true">https://community.m5stack.com/post/24398</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Fri, 15 Mar 2024 10:30:51 GMT</pubDate></item></channel></rss>
