<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[hat.DAC2.Hat missing on UiFlow for Stick2Plus]]></title><description><![CDATA[<p dir="auto">The DAC2 hat is the only hat listed in UiFLOW 2.02 for the Stick2 Plus. However, the downloader does not find it.<br />
The Alpha version has no hats to choose from. Am I missing something in my understanding of UiFlow, or is this missing from the system?</p>
]]></description><link>https://community.m5stack.com/topic/6222/hat-dac2-hat-missing-on-uiflow-for-stick2plus</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 09:38:53 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6222.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 Mar 2024 04:03:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to hat.DAC2.Hat missing on UiFlow for Stick2Plus on Tue, 14 May 2024 20:35:16 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/dlhawley" aria-label="Profile: dlhawley">@<bdi>dlhawley</bdi></a></p>
<p dir="auto">are you positive you have burnt the latest UIFlow2 firmware (e.g. v2.0.5) onto your M5Stick Plus (not 2)?</p>
<p dir="auto">I see the following line for my M5Stick Plus (not 2): <em>MicroPython v1.<strong>22</strong>.0-dirty on 2024-05-11; M5Stack StickC PLUS with ESP32</em></p>
]]></description><link>https://community.m5stack.com/post/25236</link><guid isPermaLink="true">https://community.m5stack.com/post/25236</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 14 May 2024 20:35:16 GMT</pubDate></item><item><title><![CDATA[Reply to hat.DAC2.Hat missing on UiFlow for Stick2Plus on Tue, 14 May 2024 17:45:48 GMT]]></title><description><![CDATA[<p dir="auto">I've made another pass.</p>
<p dir="auto">I am using UiFlow V2.05.</p>
<p dir="auto">I burned v2.0.5 for the StickC Plus to my stick<br />
I downloaded the official example StickCPlus2_Hat_DAC2_Example<br />
I still get: ImportError no module ns=amed 'hat.DAC2Hat'<br />
MicroPython v1.20.0-dirty on 2024-01-05</p>
]]></description><link>https://community.m5stack.com/post/25231</link><guid isPermaLink="true">https://community.m5stack.com/post/25231</guid><dc:creator><![CDATA[dlhawley]]></dc:creator><pubDate>Tue, 14 May 2024 17:45:48 GMT</pubDate></item><item><title><![CDATA[Reply to hat.DAC2.Hat missing on UiFlow for Stick2Plus on Mon, 22 Apr 2024 09:42:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi, sorry for late response.<br />
I've done some test on latest version firmware (v2.0.4) and DAC2 hat works fine. Have you update your firmware to latest version?</p>
]]></description><link>https://community.m5stack.com/post/24984</link><guid isPermaLink="true">https://community.m5stack.com/post/24984</guid><dc:creator><![CDATA[aspen]]></dc:creator><pubDate>Mon, 22 Apr 2024 09:42:12 GMT</pubDate></item><item><title><![CDATA[Reply to hat.DAC2.Hat missing on UiFlow for Stick2Plus on Fri, 05 Apr 2024 08:57:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dlhawley" aria-label="Profile: dlhawley">@<bdi>dlhawley</bdi></a></p>
<p dir="auto">I have the same problem with the NCIR-2 temp sensor not being available in the Unit selection window of UIFlow2. I decided to switch to the NCIR hat and forego the high temp alert capability of the NCIR-2 and low and behold, the hat was missing from the add hat section too.<br />
These are current products for sale in the M5 store. I think there would have been ample time to integrate them into the latest UIFlow. Worse yet, there is no way to import a missing component code into UIFlow if the lib was available on Github, etc.<br />
Problems like these are a big letdown from a company that impresses me in so many ways. I for one have started to check the units and hats I want to use and refuse to buy them if the code blocks are not there. I can edit in generic sensors from other sources but that kind of defeats the purpose of UIFlow in the first place!<br />
I feel like I am missing something too.  Good luck...</p>
<p dir="auto">PS: 229 views and everyone kept their mouth shut?</p>
]]></description><link>https://community.m5stack.com/post/24687</link><guid isPermaLink="true">https://community.m5stack.com/post/24687</guid><dc:creator><![CDATA[wmatkins]]></dc:creator><pubDate>Fri, 05 Apr 2024 08:57:04 GMT</pubDate></item><item><title><![CDATA[Reply to hat.DAC2.Hat missing on UiFlow for Stick2Plus on Wed, 03 Apr 2024 22:10:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dlhawley" aria-label="Profile: dlhawley">@<bdi>dlhawley</bdi></a><br />
It's disappointing that there's no responses here. Did I post in the wrong area? This seems like a simple problem to solve - I'd think that adding the UI images and interface would be the hard part and that loading the library would be trivial.</p>
]]></description><link>https://community.m5stack.com/post/24669</link><guid isPermaLink="true">https://community.m5stack.com/post/24669</guid><dc:creator><![CDATA[dlhawley]]></dc:creator><pubDate>Wed, 03 Apr 2024 22:10:57 GMT</pubDate></item></channel></rss>
