<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is old M5Stack stuff worth the trouble?]]></title><description><![CDATA[<p dir="auto">I bought a lot of M5Stack stuff probably around 2019 or so.  I have sensors, sticks, cameras, cars, cables, etc.  It dawned on me today, as I was charging my regular LiPo batteries, that some of the M5Stack things had batteries in it too.  I opened up the bin that had my stuff in it and I think most of the batteries are very low.  I am charging some (in a metal ammunition can, because I don't trust charging low LiPo batteries).  I also don't trust LiPo batteries that have been recharged after being low.  I see over the years, that a lot of people have asked about replacement batteries but I don't see anyone from M5 answering it.   I feel that probably it would cost me just as much to replace  batteries as buying new M5 stuff.   And I'm not sure where to get replacements that fit.  Am I right on this?  I probably will just throw the stuff back in the bin and work on the other ESP32 boards I have.  Take care everyone.  P.S, One thing that did work without recharging was my blue M5 camera.  I recharged that a little too, but go figure.  P.S.S.  What's the best way, without writing a program, to measure the battery voltage?  Are the plus and minus wires in the Grove connector equal to the battery voltage when it is turned off?  I am measuring 3.8 V on the camera on those pins, so it seems like it could be the battery voltage.</p>
]]></description><link>https://community.m5stack.com/topic/6225/is-old-m5stack-stuff-worth-the-trouble</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 09:38:47 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6225.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Mar 2024 03:26:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is old M5Stack stuff worth the trouble? on Mon, 18 Mar 2024 06:09:06 GMT]]></title><description><![CDATA[<p dir="auto">M5Stack controllers are all still supported and while batteries do die if not looked after (I have a few that need replacing) the batteries are noting special and can be found for a few dollars/pounds.</p>
<p dir="auto">Unfortunately Battery monitoring was only added to later models and the grove connector is NOT connected to the battery as it runs at 5V through a boost circuit. without writing a program the best way to check battery voltage is to open up the device and test the battery voltage with a multimeter.</p>
]]></description><link>https://community.m5stack.com/post/24421</link><guid isPermaLink="true">https://community.m5stack.com/post/24421</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 18 Mar 2024 06:09:06 GMT</pubDate></item></channel></rss>
