<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SensorHub]]></title><description><![CDATA[<p dir="auto">Hey all,</p>
<p dir="auto">I have a question regarding a project I plan.<br />
I do not have experience with the m5 stack but I have with various other ports.<br />
I am also not well experienced with I2c.<br />
From my background: I am a developer, and know various different programming languages and I also have a background in hardware development.<br />
But I think the M5 stack is perfect for my project because it does not require soldering, and that would help the users of my project to adapt.</p>
<p dir="auto">So my plan.<br />
I have ~10 different sensors to observe a small environment and this 10 times so roughly 100 sensors.<br />
These sensors I wanna read with an m5 controller but not yet sure which one, sensors I would prefer to connect over i2c.<br />
The m5controller I would connect over usb or lan with an raspberry pi for timeseries database and long term visualisation.<br />
Short term visualisation on the display of the m5controller.</p>
<p dir="auto">So my question what controller to use?<br />
How connect 100 sensors to the controller?<br />
What if the i2c sensors have same adresses?<br />
Do I need different hubs?</p>
<p dir="auto">For example I wanna use weight sensor, temperature, humidity, frequency… per environment.</p>
<p dir="auto">Regards Chris</p>
]]></description><link>https://community.m5stack.com/topic/6257/sensorhub</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 07:56:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6257.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Mar 2024 10:22:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SensorHub on Tue, 23 Apr 2024 04:46:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/idefixcert" aria-label="Profile: idefixcert">@<bdi>idefixcert</bdi></a> As long as devices have different address (and sufficient power) up to 200 devices can connect to the I2C bus (I think)</p>
]]></description><link>https://community.m5stack.com/post/24912</link><guid isPermaLink="true">https://community.m5stack.com/post/24912</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 23 Apr 2024 04:46:50 GMT</pubDate></item><item><title><![CDATA[Reply to SensorHub on Mon, 22 Apr 2024 20:51:53 GMT]]></title><description><![CDATA[<p dir="auto">Ok thanx<br />
I ordered an M5CoreInk PaHub2<br />
And sensors.<br />
Now I have some more questions.<br />
I am able to read the I2C sensors.<br />
The pahub2 does not work yet, I have a conflict with one of the sensors. Need to solder a bit. But Q1: is there a library out there for PaHub2?</p>
<p dir="auto">Q2:<br />
I2c bus is already in use. I also wanna use the scale kit but I struggle to figure out which other pins I can use for the scale kit. Anyone who can help?<br />
Also I have seen there is a I2c version of the scale controller, I think I will order it because I wanna use more than one scale kit, or is this also with the original controller possible?</p>
]]></description><link>https://community.m5stack.com/post/24903</link><guid isPermaLink="true">https://community.m5stack.com/post/24903</guid><dc:creator><![CDATA[idefixcert]]></dc:creator><pubDate>Mon, 22 Apr 2024 20:51:53 GMT</pubDate></item><item><title><![CDATA[Reply to SensorHub on Sun, 24 Mar 2024 11:06:23 GMT]]></title><description><![CDATA[<p dir="auto">Any controller will work, I have mine send to an MQTT server hosted on an RPI4.</p>
<p dir="auto">100 may work but you will run into power issues.</p>
<p dir="auto">If you have more then 1 I2C sensor with the same address, you will need to use the PaHub for the up to 6 sensors .</p>
<p dir="auto">You can connect more then 1 hub to the I2C bus but you will need to make sure you have different Hub address.</p>
]]></description><link>https://community.m5stack.com/post/24556</link><guid isPermaLink="true">https://community.m5stack.com/post/24556</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 24 Mar 2024 11:06:23 GMT</pubDate></item></channel></rss>
