<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[BUG &#x2F; FEATURE REQUEST: Slow upload speed, no way to change baud rate]]></title><description><![CDATA[<p dir="auto">I am programming using UiFlow 2.0 on my <em>M5Stack Stick C Plus 2</em>.</p>
<p dir="auto">When I burn UiFlow 2.0 using M5Burner, the tool shows <em>esptool</em> being used, which reports the file size being <em>~20KB</em>.<br />
This is very fast (less than 10 seconds).</p>
<p dir="auto">When I use UiFlow 2.0's web interface to upload via a USB COM port, however, my file is <em>~20KB</em>, It is very very slow (~90 seconds).</p>
<p dir="auto">It would greatly benefit me (and others) to have the option to change the baud rate.</p>
<p dir="auto">EDIT:<br />
I almost forgot, the issue also happens when I upload a file from the web terminal.<br />
There is also an issue when I upload a file or script, it results in an empty (0 Bytes) file! (most of the time)</p>
<p dir="auto">EDIT 2:<br />
I found a partial solution to my problem:<br />
I find that the files have a smaller chance to be uploaded empty when you shut down the device using the power button,<br />
then plug the device without turning it on and upload files that way.</p>
<p dir="auto">The upload speed is still very slow.</p>
]]></description><link>https://community.m5stack.com/topic/6263/bug-feature-request-slow-upload-speed-no-way-to-change-baud-rate</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:43:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6263.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Mar 2024 23:16:39 GMT</pubDate><ttl>60</ttl></channel></rss>
