<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Anyone using PlatformIO?  Unable to get serial terminal to work.]]></title><description><![CDATA[<p dir="auto">Does anyone here use platform IO?  I am unable to get the serial monitor to see what I print to the serial monitor.  Anyone else have this issue?</p>
<p dir="auto">Main.cpp</p>
#include &lt;M5Unified.h&gt;
int counter1 = 0;
  auto cfg = M5.config();
  M5.begin(cfg);
  delay(500);
  M5.Display.setTextSize(2);
  M5.update();
  M5.Display.setCursor(0, 20);
  M5.Display.print("C1: ");
  M5.Display.print(counter1);
  Serial.println(counter1);
  delay(200);
  counter1++;
<p dir="auto">Platform.ini</p>
<pre><code>[env:m5stack-atoms3]
platform = espressif32
board = m5stack-atoms3
framework = arduino
monitor_speed = 115200
monitor_rts = 0
monitor_dtr = 0
monitor_raw = yes
lib_deps = m5stack/M5Unified@^0.1.13
]]></description><link>https://community.m5stack.com/topic/6280/anyone-using-platformio-unable-to-get-serial-terminal-to-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:29:45 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6280.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 Mar 2024 19:54:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Anyone using PlatformIO?  Unable to get serial terminal to work. on Sun, 31 Mar 2024 23:29:50 GMT]]></title><description><![CDATA[<p dir="auto">Thanks guys adding the build flags fixed the blank serial terminal in PlatformIO.</p>
]]></description><link>https://community.m5stack.com/post/24627</link><guid isPermaLink="true">https://community.m5stack.com/post/24627</guid><dc:creator><![CDATA[LukeS]]></dc:creator><pubDate>Sun, 31 Mar 2024 23:29:50 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone using PlatformIO?  Unable to get serial terminal to work. on Sun, 31 Mar 2024 21:02:29 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/lukes" aria-label="Profile: LukeS">@<bdi>LukeS</bdi></a></p>
<p dir="auto">please see this <a href="https://community.m5stack.com/topic/5858/serial-not-working-with-m5unified-on-atoms3/3">thread</a> for a solution.</p>
]]></description><link>https://community.m5stack.com/post/24621</link><guid isPermaLink="true">https://community.m5stack.com/post/24621</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 31 Mar 2024 21:02:29 GMT</pubDate></item><item><title><![CDATA[Reply to Anyone using PlatformIO?  Unable to get serial terminal to work. on Sun, 31 Mar 2024 20:59:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukes" aria-label="Profile: lukes">@<bdi>lukes</bdi></a> In Arduino IDE you need to set the comm settings to USB CDC on Boot "Enabled", with S3 boards.</p>
]]></description><link>https://community.m5stack.com/post/24620</link><guid isPermaLink="true">https://community.m5stack.com/post/24620</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sun, 31 Mar 2024 20:59:54 GMT</pubDate></item></channel></rss>
