<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Arduino &amp; TimerCameraX - webcam examples just don&#x27;t work]]></title><description><![CDATA[<p dir="auto">I'm trying to use a TimerCameraX with Arduino, with the latest versions of everything.</p>
<p dir="auto">Both of the Timer-CAM webcam examples (sta and ap) work for a little while, then become very intermittent, then stop delivering frames altogether.</p>
<p dir="auto">Are these examples meant to work correctly with the TimerCameraX ? Should I be looking somewhere else for decent examples ?</p>
<p dir="auto">Thanks,<br />
Richard</p>
]]></description><link>https://community.m5stack.com/topic/6309/arduino-timercamerax-webcam-examples-just-don-t-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 10:04:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6309.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 07 Apr 2024 15:56:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Arduino &amp; TimerCameraX - webcam examples just don&#x27;t work on Wed, 17 Apr 2024 12:54:23 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/jarkman" aria-label="Profile: jarkman">@<bdi>jarkman</bdi></a></p>
<p dir="auto">I am afraid I am out of ideas at this point in time. Sorry.</p>
]]></description><link>https://community.m5stack.com/post/24847</link><guid isPermaLink="true">https://community.m5stack.com/post/24847</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 17 Apr 2024 12:54:23 GMT</pubDate></item><item><title><![CDATA[Reply to Arduino &amp; TimerCameraX - webcam examples just don&#x27;t work on Tue, 16 Apr 2024 17:21:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> - thanks. I had PSRAM enabled but perhaps not the right partition scheme.</p>
<p dir="auto">I now have PSRAM enabled and I'm using the default partition scheme ('default 4MB with spiffs...').</p>
<p dir="auto">I see it</p>
<li>working with FRAMESIZE_QVGA (320x200)</li>
<li>working but frequently blocking for several seconds with FRAMESIZE_SVGA (800x600) as in the original sample</li>
<li>crashing instantly with FRAMESIZE_QXGA (2048x1536)</li>
<p dir="auto">Any thoughts ?</p>
<p dir="auto">thanks,<br />
Richard</p>
]]></description><link>https://community.m5stack.com/post/24831</link><guid isPermaLink="true">https://community.m5stack.com/post/24831</guid><dc:creator><![CDATA[jarkman]]></dc:creator><pubDate>Tue, 16 Apr 2024 17:21:54 GMT</pubDate></item><item><title><![CDATA[Reply to Arduino &amp; TimerCameraX - webcam examples just don&#x27;t work on Fri, 12 Apr 2024 21:17:36 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/jarkman" aria-label="Profile: jarkman">@<bdi>jarkman</bdi></a></p>
<p dir="auto">I assume you already have PSRAM enabled in your build, yes?</p>
<p dir="auto">BTW: Not sure why but changing the frame_size from FRAMESIZE_QVGA to the camera native FRAMESIZE_QXGA helped a lot.</p>
]]></description><link>https://community.m5stack.com/post/24771</link><guid isPermaLink="true">https://community.m5stack.com/post/24771</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 12 Apr 2024 21:17:36 GMT</pubDate></item></channel></rss>
