<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m5stickc plus 2 cannot be flashed]]></title><description><![CDATA[<p dir="auto">I bought m5stickc plus 2 quite recently, I started testing different firmware, first marauder, then decided to download nemo, but after installing nemo, the screen stopped going out, and now when connecting and trying to flash it, it gives an error<br />
etc Jul 29 2019 12:21:46</p>
<p dir="auto">rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))<br />
waiting for download<br />
And also writes: you must log in before using this firmware<br />
please help me, I have not found any information about this anywhere, and I do not have special programming skills (((</p>
]]></description><link>https://community.m5stack.com/topic/6335/m5stickc-plus-2-cannot-be-flashed</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 17:31:05 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6335.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Apr 2024 05:45:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m5stickc plus 2 cannot be flashed on Thu, 10 Oct 2024 15:37:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bbarker23" aria-label="Profile: bbarker23">@<bdi>bbarker23</bdi></a> well, have you tried installing the driver?</p>
]]></description><link>https://community.m5stack.com/post/26682</link><guid isPermaLink="true">https://community.m5stack.com/post/26682</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 10 Oct 2024 15:37:03 GMT</pubDate></item><item><title><![CDATA[Reply to m5stickc plus 2 cannot be flashed on Tue, 08 Oct 2024 16:17:47 GMT]]></title><description><![CDATA[<p dir="auto">im trying to flash but it keeps saying this</p>
<p dir="auto">Detecting chip type...<br />
ESP32<br />
Chip is ESP32-PICO-V3-02 (revision v3.1)<br />
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None<br />
Crystal is 40MHz<br />
MAC: 14:2b:2f:b2:0b:14<br />
Uploading stub...</p>
<p dir="auto">Note: If issues persist, try installing the WCH USB-to-Serial MacOS driver.</p>
<p dir="auto">A fatal error occurred: Failed to write to target RAM (result was 01070000: Operation timed out)</p>
]]></description><link>https://community.m5stack.com/post/26658</link><guid isPermaLink="true">https://community.m5stack.com/post/26658</guid><dc:creator><![CDATA[bbarker23]]></dc:creator><pubDate>Tue, 08 Oct 2024 16:17:47 GMT</pubDate></item><item><title><![CDATA[Reply to m5stickc plus 2 cannot be flashed on Mon, 15 Apr 2024 08:59:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robski" aria-label="Profile: robski">@<bdi>robski</bdi></a> Thanks, it helped</p>
]]></description><link>https://community.m5stack.com/post/24806</link><guid isPermaLink="true">https://community.m5stack.com/post/24806</guid><dc:creator><![CDATA[Fedor_bug]]></dc:creator><pubDate>Mon, 15 Apr 2024 08:59:54 GMT</pubDate></item><item><title><![CDATA[Reply to m5stickc plus 2 cannot be flashed on Mon, 15 Apr 2024 07:28:14 GMT]]></title><description><![CDATA[<p dir="auto">Open M5Burner, log in to your M5stack account, pick M5StickCplus2 latest firmware, choose right com port press burn, or you can do erase and then burn.</p>
]]></description><link>https://community.m5stack.com/post/24804</link><guid isPermaLink="true">https://community.m5stack.com/post/24804</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 15 Apr 2024 07:28:14 GMT</pubDate></item></channel></rss>
