<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Product Revision] TailBat with Battery Management that doesn&#x27;t suck]]></title><description><![CDATA[<p dir="auto">Replace the Battery Management IC with one that:</p>
<li>Has low voltage cutoff (to prevent damage to battery)</li>
<li>Has no low current cutoff (interferes with long runtime and using deep sleep)</li>
<li>Battery charge &amp; state info (via I2C with internal switch to connect/disconnect from Grove port)</li>
]]></description><link>https://community.m5stack.com/topic/6368/product-revision-tailbat-with-battery-management-that-doesn-t-suck</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:06:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6368.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Apr 2024 21:31:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Product Revision] TailBat with Battery Management that doesn&#x27;t suck on Fri, 26 Apr 2024 16:00:02 GMT]]></title><description><![CDATA[<p dir="auto">lots of good things in feature forum!</p>
]]></description><link>https://community.m5stack.com/post/24955</link><guid isPermaLink="true">https://community.m5stack.com/post/24955</guid><dc:creator><![CDATA[Ifantus]]></dc:creator><pubDate>Fri, 26 Apr 2024 16:00:02 GMT</pubDate></item><item><title><![CDATA[Reply to [Product Revision] TailBat with Battery Management that doesn&#x27;t suck on Wed, 24 Apr 2024 14:32:49 GMT]]></title><description><![CDATA[<p dir="auto">The current one does suck, lol. Mainly only good as a UPS or if you need to run your thing for only a few hours since you can't sleep for longer standby use.</p>
]]></description><link>https://community.m5stack.com/post/24923</link><guid isPermaLink="true">https://community.m5stack.com/post/24923</guid><dc:creator><![CDATA[Cairnus]]></dc:creator><pubDate>Wed, 24 Apr 2024 14:32:49 GMT</pubDate></item></channel></rss>
