<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow2.0 could not burnned correctly into M5Stack basic(Core)]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">I tried to burn UIFlow2.0(v2.0.4-16MB) with M5burner but it seems not correctly burned.<br />
Below is the result of M5burner. I feel M5burner burned very small amount.<br />
(It wrote just only 24576bytes)<br />
Also I tried to burn UIflow1, then it worked fine, no problem.<br />
Additionally I tested with AtomS3U/UIFlow2.0.4. It also no problem.</p>
<p dir="auto">Could someone please help me?<br />
What settings should I check?</p>
<p dir="auto">----------result of burn UIFlow2.0.4 into M5Stack basic----<br />
Detecting chip type...<br />
ESP32<br />
Chip is ESP32-D0WDQ6-V3 (revision v3.0)<br />
Crystal is 40MHz<br />
MAC: 78:21:84:a6:58:4c<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Auto-detected Flash size: 16MB<br />
Flash will be erased from 0x00009000 to 0x0000efff...<br />
Compressed 24576 bytes to 470...<br />
Writing at 0x00009000... (100 %)<br />
Wrote 24576 bytes (470 compressed) at 0x00009000 in 0.3 seconds (effective 569.3 kbit/s)...<br />
Hash of data verified.</p>
<p dir="auto">Leaving...<br />
Hard resetting via RTS pin...</p>
<p dir="auto">----------result of burn UIFlow1.13.4 into M5Stack basic----<br />
ESP32<br />
Changing baud rate to 921600<br />
Changed.<br />
Flash will be erased from 0x003ff000 to 0x003fffff...<br />
Flash will be erased from 0x00000000 to 0x003fdfff...<br />
Compressed 100 bytes to 31...<br />
Writing at 0x003ff000... (100 %)<br />
Wrote 100 bytes (31 compressed) at 0x003ff000 in 0.0 seconds (effective 18.3 kbit/s)...<br />
Hash of data verified.<br />
Compressed 4186112 bytes to 2526007...<br />
Writing at 0x00000000... (0 %)<br />
Writing at 0x00010bfa... (1 %)<br />
Writing at 0x00017cfe... (1 %)<br />
Writing at 0x00020bd2... (2 %)<br />
.....<br />
Writing at 0x003fd154... (100 %)<br />
Wrote 4186112 bytes (2526007 compressed) at 0x00000000 in 40.2 seconds (effective 833.1 kbit/s)...<br />
<p dir="auto">----------result of burn UIFlow2.0.4 into ATOMS3U----<br />
--chip auto --port COM5 --baud 921600 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x000 C:\Users\ABC\Documents\M5burner\packages\tmp\uiflow2-mixin.bin<br />
<a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v4.6.2<br />
Serial port COM5<br />
Connecting...</p>
<p dir="auto">Detecting chip type... ESP32-S3<br />
Chip is ESP32-S3 (revision v0.1)<br />
Features: WiFi, BLE<br />
MAC: 70:04:1d:d3:52:48<br />
Changed.<br />
Auto-detected Flash size: 8MB<br />
Flash will be erased from 0x00000000 to 0x007fefff...<br />
Compressed 8384512 bytes to 3140155...<br />
Writing at 0x000127c8... (1 %)<br />
...<br />
Writing at 0x0057da35... (99 %)<br />
Writing at 0x0070947b... (100 %)<br />
Wrote 8384512 bytes (3140155 compressed) at 0x00000000 in 36.8 seconds (effective 1820.8 kbit/s)...<br />
<h2>Leaving...<br />
Hard resetting via RTS pin...</h2>
<p dir="auto">Thank you<br />
Regards</p>
]]></description><link>https://community.m5stack.com/topic/6447/uiflow2-0-could-not-burnned-correctly-into-m5stack-basic-core</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:30:19 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6447.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 May 2024 05:35:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow2.0 could not burnned correctly into M5Stack basic(Core) on Fri, 24 May 2024 14:04:11 GMT]]></title><description><![CDATA[<p dir="auto">I have the same problem with UIFlow2 and Core Basic.</p>
]]></description><link>https://community.m5stack.com/post/25385</link><guid isPermaLink="true">https://community.m5stack.com/post/25385</guid><dc:creator><![CDATA[mroziken]]></dc:creator><pubDate>Fri, 24 May 2024 14:04:11 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 could not burnned correctly into M5Stack basic(Core) on Wed, 15 May 2024 04:13:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a><br />
Thanks for your reply.<br />
I tried several times and found what am I wrong.</p>
<p dir="auto">I was wrote only configuration with "Configure" button in M5burner.<br />
Then it burned just only configuration but no other firmware.</p>
<p dir="auto">So it should burn with "Burn" button.  Then firmware and configuration were written correctly.</p>
<p dir="auto">Thanks for your help.<br />
Regards</p>
]]></description><link>https://community.m5stack.com/post/25240</link><guid isPermaLink="true">https://community.m5stack.com/post/25240</guid><dc:creator><![CDATA[ymd_m]]></dc:creator><pubDate>Wed, 15 May 2024 04:13:47 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 could not burnned correctly into M5Stack basic(Core) on Fri, 10 May 2024 04:37:28 GMT]]></title><description><![CDATA[<p dir="auto">only v2.0.4- 4MB version will work on the core, the 16MB is for the fire version.<br />
I have the Core and the Go sat on my desk here running UIFlow 2 and I made a video on it.<br />
<a href="https://youtu.be/Z1i93cYSPIQ?si=lDVZ7rP7oACUCaQO" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/Z1i93cYSPIQ?si=lDVZ7rP7oACUCaQO</a></p>
]]></description><link>https://community.m5stack.com/post/25164</link><guid isPermaLink="true">https://community.m5stack.com/post/25164</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 10 May 2024 04:37:28 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 could not burnned correctly into M5Stack basic(Core) on Fri, 10 May 2024 02:11:58 GMT]]></title><description><![CDATA[<p dir="auto">Hello ajb2k3.<br />
Thanks for your reply.</p>
<p dir="auto">Yes, I erased before burnning.</p>
<p dir="auto">The problem is no response when writing program into M5stack Basic with Web Terminal. (Just only displaying "Progress:" and progrss bar did not forwarding.)<br />
<img src="https://i.imgur.com/fQPo7iT.png" alt="UIFlow2" class=" img-fluid img-markdown" /></p>
<p dir="auto">It occures only combination with UIFlow2 and M5Stack basic.<br />
(it is ok UIFlow1 and M5stack basic,  also UIFlow2 and ATOMS3U is no probelm.)</p>
<p dir="auto">Thus I assume UIFlow2 is not burnned correctly into my M5Stack Basic.<br />
(In problem case, 24576 bytes was written. However other successed cases, 4186112bytes or 8384512 bytes written. I feel 24576bytes is too much small than oter cases. )</p>
<p dir="auto">Also I tried to burnning UIFlow 2.0.3(4MB and 16MB) and 2.0.4(4MB and 16MB) with M5Burner but these were same result. (I tested UIFlow2.0. NOT UIFlow2.0 Fire)<br />
<img src="https://i.imgur.com/D7HIFk3.png" alt="M5burner" class=" img-fluid img-markdown" /></p>
<p dir="auto">So could you please let me know it you have any suggestions as to what shall I check?</p>
Regards</p>
]]></description><link>https://community.m5stack.com/post/25163</link><guid isPermaLink="true">https://community.m5stack.com/post/25163</guid><dc:creator><![CDATA[ymd_m]]></dc:creator><pubDate>Fri, 10 May 2024 02:11:58 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow2.0 could not burnned correctly into M5Stack basic(Core) on Thu, 09 May 2024 11:57:47 GMT]]></title><description><![CDATA[<p dir="auto">That says all is correct<br />
Are you erasing before burning?<br />
Are you making sure to burn the correct version?<br />
What’s the problem?</p>
]]></description><link>https://community.m5stack.com/post/25155</link><guid isPermaLink="true">https://community.m5stack.com/post/25155</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 09 May 2024 11:57:47 GMT</pubDate></item></channel></rss>
