<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5stack PoESP32 - Where can I find preinstalled ESP-AT Firmware]]></title><description><![CDATA[<p dir="auto">Hi community,</p>
<p dir="auto">I flashed my M5stack PoESP32 through the Arduino IDE to connect to a MQTT broker using this example: <a href="https://github.com/m5stack/M5Unit-PoESP32/blob/master/examples/Unit_PoESP32_M5Atom/MQTT_CLIENT/MQTT_CLIENT.ino" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Unit-PoESP32/blob/master/examples/Unit_PoESP32_M5Atom/MQTT_CLIENT/MQTT_CLIENT.ino</a></p>
<p dir="auto">Now I'm trying to get the firmware back to it's shipped state and can not get it to work.<br />
I've followed the instruction given on <a href="https://docs.espressif.com/projects/esp-at/en/latest/esp32/Get_Started/Downloading_guide.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.espressif.com/projects/esp-at/en/latest/esp32/Get_Started/Downloading_guide.html</a> and managed to flash the latest  ESP32 WROOM firmware (<a href="https://dl.espressif.com/esp-at/firmwares/esp32/ESP32-WROOM-32/ESP32-WROOM-32-AT-V3.2.0.0.zip" target="_blank" rel="noopener noreferrer nofollow ugc">https://dl.espressif.com/esp-at/firmwares/esp32/ESP32-WROOM-32/ESP32-WROOM-32-AT-V3.2.0.0.zip</a>) on to the board. With this firmware the ethernet connection however does not work at all. The LEDs on the ETH port don't light up. The unit is pretty much dead.</p>
<p dir="auto">I managed to get the eth port going again by following these instructions: <a href="https://github.com/DrJohnM61/poesp32-esphome" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/DrJohnM61/poesp32-esphome</a>. This enables the the M5stack PoESP32 to receive an IP address, but the communication with the M5ATOM through the serial link does not work.</p>
<p dir="auto">Long story short, where can I find the factory preinstalled firmware for the M5stack PoESP32 board, so that I can flash it?</p>
<p dir="auto">Thanks for your support<br />
Chris</p>
]]></description><link>https://community.m5stack.com/topic/6457/m5stack-poesp32-where-can-i-find-preinstalled-esp-at-firmware</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 01:59:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6457.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 May 2024 08:31:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5stack PoESP32 - Where can I find preinstalled ESP-AT Firmware on Sun, 12 May 2024 09:15:14 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/stoeff99" aria-label="Profile: stoeff99">@<bdi>stoeff99</bdi></a></p>
<p dir="auto">from what I can tell the firmware versions offered by Espressif do not have Ethernet enabled by default. I also do not think M5Stack is offering the preinstalled ESP-AT firmware binary on their website.</p>
<p dir="auto">That said you could try to configure and compile the ESP-AT firmware yourself by following the steps outlined <a href="https://docs.espressif.com/projects/esp-at/en/latest/esp32/Compile_and_Develop/How_to_clone_project_and_compile_it.html" target="_blank" rel="noopener noreferrer nofollow ugc">here</a> and <a href="https://docs.espressif.com/projects/esp-at/en/latest/esp32/Compile_and_Develop/How_to_enable_ESP_AT_Ethernet.html" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/25194</link><guid isPermaLink="true">https://community.m5stack.com/post/25194</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 12 May 2024 09:15:14 GMT</pubDate></item></channel></rss>
