<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core 2 with GRBL 13.2 Module]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I'm currently working with a Core 2 v1.1 ESP32 and GRBL module 13.2, and I'm encountering an issue with my stepper motor setups. Here are the details of my configuration:</p>
<p dir="auto">Controller: Core 2 v1.1 ESP32<br />
GRBL Module: Version 13.2<br />
Power Supply: 12V, 3A<br />
Stepper Motor: normal Bondtech NEMA17 Pancake Stepper, 25mm<br />
Software: UI Flow<br />
Step Subdivision: 1/32 Step</p>
<p dir="auto"><em><strong>Issue:</strong></em></p>
<p dir="auto">The stepper motor only functions correctly in the Z axis at normal (slow) rotation speeds.<br />
When attempting to use the X and Y axes, the motor does not work unless I increase the feed rates to 10x or higher.<br />
When i try to change the adress to 0x71 the module is not beeing recognised.</p>
<p dir="auto"><strong>Troubleshooting Done:</strong></p>
<p dir="auto">I've tried changing the step subdivision and the power supply settings.<br />
I've tested this setup with 5 different GRBL modules, and the issue persists across all of them.</p>
<p dir="auto">Could this be a bug in the GRBL module? I'm wondering if anyone else has experienced similar issues or has any suggestions on what else I can try. Any help would be greatly appreciated!</p>
<p dir="auto">Thanks in advance for your quick responses!</p>
]]></description><link>https://community.m5stack.com/topic/6464/core-2-with-grbl-13-2-module</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 08:49:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6464.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 May 2024 14:45:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core 2 with GRBL 13.2 Module on Wed, 22 May 2024 07:01:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/revilo_oli" aria-label="Profile: Revilo_oli">@<bdi>Revilo_oli</bdi></a><br />
With some testing it was found that  the core 2 was faulty and it had to be replaced</p>
]]></description><link>https://community.m5stack.com/post/25350</link><guid isPermaLink="true">https://community.m5stack.com/post/25350</guid><dc:creator><![CDATA[Revilo_oli]]></dc:creator><pubDate>Wed, 22 May 2024 07:01:02 GMT</pubDate></item></channel></rss>
