<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 tough..getting started issue...]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I just bought my first m5 tough (first m5 device every), so everything is new to me.<br />
Installed the driver : ok (device connected on COM4)<br />
Could write the firmware to UIflow2.0 (2.0.5-Tough) with M5 burner (logged in to my account).</p>
<p dir="auto">I can't get write any program to the device via web uiflow2. It's possible to connect, but when writing a program a just hangs.<br />
Also the device is not bound to my account.<br />
On the M5 tough device itself, I am seeing "Tough Tools" and serveral menu-items on the bottom of the screen wirfi, touch, I2C,etc...)<br />
Searched for many hours , but documentation is not very basic and unclear. Getting frustrated...not a fluent start...<br />
Who can help me ?</p>
]]></description><link>https://community.m5stack.com/topic/6484/m5-tough-getting-started-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:02:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6484.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 May 2024 12:45:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 tough..getting started issue... on Sun, 19 May 2024 07:18:20 GMT]]></title><description><![CDATA[<p dir="auto">You have missed a step there, you must Erase the existing firmware before burning new firmware.</p>
]]></description><link>https://community.m5stack.com/post/25326</link><guid isPermaLink="true">https://community.m5stack.com/post/25326</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 19 May 2024 07:18:20 GMT</pubDate></item><item><title><![CDATA[Reply to M5 tough..getting started issue... on Sat, 18 May 2024 20:01:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wouter" aria-label="Profile: wouter">@<bdi>wouter</bdi></a></p>
<p dir="auto">that is strange indeed. I have no idea as to why after as successful burning of V2.0.5-Tough your device would still boot up with the previous factory installed firmware. Maybe try to erase first?</p>
]]></description><link>https://community.m5stack.com/post/25324</link><guid isPermaLink="true">https://community.m5stack.com/post/25324</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 18 May 2024 20:01:17 GMT</pubDate></item><item><title><![CDATA[Reply to M5 tough..getting started issue... on Sat, 18 May 2024 15:57:39 GMT]]></title><description><![CDATA[<p dir="auto">I've just started working with M5 Tough (about a month). I can execute some code and tinker with the basics as I attempt to do something more advanced. I can answer some basic things I have tried.</p>
<p dir="auto">The simple stuff:<br />
I flashed the UIFLow 2.0 firmware using m5burner<br />
Used the web uiflow software to write a basic program and pushed it onto the device.<br />
Then, I connected to the device using Thonny. I can now write code in <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a> (using UIFlow web IDE to figure out some code blocks and copy it into the <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a>)</p>
<p dir="auto">The things I am working on: (the documentation is terrible)</p>
<li>Connect the device to a Bluetooth speaker</li>
<li>Read a music file from an SD card and play it over Bluetooth</li>
]]></description><link>https://community.m5stack.com/post/25322</link><guid isPermaLink="true">https://community.m5stack.com/post/25322</guid><dc:creator><![CDATA[that_design_student]]></dc:creator><pubDate>Sat, 18 May 2024 15:57:39 GMT</pubDate></item><item><title><![CDATA[Reply to M5 tough..getting started issue... on Sat, 18 May 2024 14:18:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a><br />
Hi thank your for your answer.  Yes I read the m5stackwebsite, google, youtube... but not many things about the M5 tough, or how to get started. I understood quickly I needed to do a firmware flash to uiflow2, but that doesn't seem to work for some reason.  If you can point me to some usefull info I would certainly appreciate this.<br />
I think find and bind will only work if I get the UIflow2 firmware working ?</p>
]]></description><link>https://community.m5stack.com/post/25320</link><guid isPermaLink="true">https://community.m5stack.com/post/25320</guid><dc:creator><![CDATA[wouter]]></dc:creator><pubDate>Sat, 18 May 2024 14:18:22 GMT</pubDate></item><item><title><![CDATA[Reply to M5 tough..getting started issue... on Sat, 18 May 2024 14:15:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a><br />
Hi, yes you are correct, I already suspected something like this.But I can't figure out why UIFlow is not running.<br />
When I look in the M5 burner, and I search for "Tough" I do find "tough_tools" and the display currently looks exactly like this.(as you mentioned).</p>
<p dir="auto">I can also find UIFlow_Tough, this is for the V1 uiflow I suppose.<br />
For the UIFlow2.0 I can find "Uiflow2.0 (core2/tough/Core2 v1.1).<br />
Here I select V2.0.5-Tough. Then Download.<br />
Then Configure -&gt; COM4, I  add the wifi settings, and time zone.<br />
I select : show startup menu and network setup<br />
Powermode : USB IN BUSOUT<br />
Then Next -&gt; It says Burning</p>
<p dir="auto">.</p>
<p dir="auto">Detecting chip type...<br />
ESP32<br />
Chip is ESP32-D0WDQ6-V3 (revision v3.1)<br />
Crystal is 40MHz<br />
MAC: 08:f9:e0:d2:66:f4<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Changing baud rate to 1500000<br />
Changed.<br />
Auto-detected Flash size: 16MB<br />
Flash will be erased from 0x00009000 to 0x0000efff...<br />
Compressed 24576 bytes to 503...<br />
Writing at 0x00009000... (100 %)<br />
Wrote 24576 bytes (503 compressed) at 0x00009000 in 0.3 seconds (effective 663.5 kbit/s)...<br />
Hash of data verified.</p>
<p dir="auto">Leaving...<br />
Hard resetting via RTS pin...<br />
"Burn Sucessfully"</p>
<p dir="auto">Did a long press on the side button to turn it off, turn it back on via the button.<br />
Turned off the power by removing the usb cable and put it back in.</p>
<p dir="auto">And then.....everything stays the same on the device ?<br />
What am I missing ?</p>
]]></description><link>https://community.m5stack.com/post/25319</link><guid isPermaLink="true">https://community.m5stack.com/post/25319</guid><dc:creator><![CDATA[wouter]]></dc:creator><pubDate>Sat, 18 May 2024 14:15:09 GMT</pubDate></item><item><title><![CDATA[Reply to M5 tough..getting started issue... on Sat, 18 May 2024 06:12:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wouter" aria-label="Profile: wouter">@<bdi>wouter</bdi></a></p>
<p dir="auto">I don't think your M5Tough is actually running UIFlow2 since you are writing that you're seeing <em>"Tough Tools" and several menu-items on the bottom</em>. I think it is still running the Tough Tools firmware it came with (which is different from UIFlow2 firmware).</p>
<p dir="auto">When UIFlow2 is running on your M5Tough it does say so on the screen. On screen at the top from left to right you should see: UIFlow2 / Time / WiFi signal / Cloud connection state / Battery state.</p>
]]></description><link>https://community.m5stack.com/post/25317</link><guid isPermaLink="true">https://community.m5stack.com/post/25317</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 18 May 2024 06:12:28 GMT</pubDate></item><item><title><![CDATA[Reply to M5 tough..getting started issue... on Fri, 17 May 2024 14:40:44 GMT]]></title><description><![CDATA[<p dir="auto">Did you erase find and bind to your account because it doesn’t appear so.<br />
Did you check the website, google or YouTube? But documentation is available</p>
]]></description><link>https://community.m5stack.com/post/25313</link><guid isPermaLink="true">https://community.m5stack.com/post/25313</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 17 May 2024 14:40:44 GMT</pubDate></item></channel></rss>
