<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CORE2 v1.1 does not power up when battery connected]]></title><description><![CDATA[<p dir="auto">I am using the CORE2 with an external battery. The rear cover and battery are removed and the M-BUS connector is plugged into a header on the system main board. I have a SPST On/Off switch between the battery and the BATT pin (M-BUS pin 30).<br />
With the original CORE2, using the AXP192, the module would power up on battery connection when the switch was closed. Now, with the AXP2101, it's a two-step operation: close switch, then hold the power button on the side of the module to power up.<br />
What I'm trying to do is restore the original behaviour: switch only.<br />
Reading the AXP2101 datasheet:<br />
<em>6.5.2<br />
Power up from BAT<br />
If only battery is present and VBAT is higher than depletion threshold (VBAT_DPLZ), BATFET, connecting battery to system, is off by default and need to be turned on by pressing the PWRON key or inserting an adapter.</em><br />
It seems pretty hopeless. Is there something else in the CORE2 v1.1 that I'm missing that could be used as a work-around?<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/6495/core2-v1-1-does-not-power-up-when-battery-connected</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:41:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6495.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 May 2024 01:43:02 GMT</pubDate><ttl>60</ttl></channel></rss>
