<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Range of GoPlus2 command]]></title><description><![CDATA[<p dir="auto">Hello, I try to use a GoPlus2 module in two way :<br />
First to command directly DC brushed motors,<br />
Second to command brushed motor through ESC.<br />
For the first way, I want to know the range of the motorSpeed for the method goPlus.Motor_write_speed(). In the example of the "documentation", the user set the motorSpeed between (-127,127)?<br />
For the second way, I want to know the range of the width for the method goPlus.Servo_write_plusewidth(). I want generate a pulse between 1ms and 2ms.<br />
Thank you for your help. If there's a precise documentation about GoPlus2 module, I'm a taker</p>
]]></description><link>https://community.m5stack.com/topic/6503/range-of-goplus2-command</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 08:35:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6503.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 May 2024 09:17:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Range of GoPlus2 command on Sat, 25 May 2024 11:43:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/totoche" aria-label="Profile: Totoche">@<bdi>Totoche</bdi></a> -127 is reverse 0 is off and 127 is forwards, the full output voltage is limited to 5v I haven’t measured current but I have been able to run a OO gauge model railway at 5V from the output pins.<br />
PWM pulse is set to the normal servo pulse frequencies</p>
]]></description><link>https://community.m5stack.com/post/25392</link><guid isPermaLink="true">https://community.m5stack.com/post/25392</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 25 May 2024 11:43:50 GMT</pubDate></item></channel></rss>
