<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[f_mount failed: (3) The physical drive cannot work]]></title><description><![CDATA[<p dir="auto">Hi guys, im having trouble trying to use my SD card in my m5cardputer, i already tried format the sd card to FAT32</p>
<p dir="auto">error :<br />
[  1110][W][sd_diskio.cpp:547] ff_sd_initialize(): APP_OP_COND failed: 1<br />
[  1110][E][sd_diskio.cpp:805] sdcard_mount(): f_mount failed: (3) The physical drive cannot work<br />
Card Mount Failed</p>
<p dir="auto">Im using the SD_Test example and the sd card is a SanDisk 16gb made in Taiwan</p>
]]></description><link>https://community.m5stack.com/topic/6518/f_mount-failed-3-the-physical-drive-cannot-work</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 15:14:52 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6518.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 May 2024 15:02:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to f_mount failed: (3) The physical drive cannot work on Fri, 31 May 2024 19:13:54 GMT]]></title><description><![CDATA[<p dir="auto">After some research i found that sandisk made in Taiwan can happen this problem, i tested with another sd card and its all good.</p>
]]></description><link>https://community.m5stack.com/post/25440</link><guid isPermaLink="true">https://community.m5stack.com/post/25440</guid><dc:creator><![CDATA[kernel_panic1]]></dc:creator><pubDate>Fri, 31 May 2024 19:13:54 GMT</pubDate></item></channel></rss>
