<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Product Revision] Color Sensor (U009) - Ability to turn off LEDs]]></title><description><![CDATA[<p dir="auto">It would be nice if there was a revision of the color sensor that allows the LEDs to be turned off/on (via I2C). So it can be used for measuring a light source's color spectrum (leds off) as well as an object's color (leds on).</p>
]]></description><link>https://community.m5stack.com/topic/6531/product-revision-color-sensor-u009-ability-to-turn-off-leds</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:31:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6531.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Jun 2024 16:32:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Product Revision] Color Sensor (U009) - Ability to turn off LEDs on Sat, 25 Jan 2025 02:33:44 GMT]]></title><description><![CDATA[<p dir="auto">It would be awesome to have one with UV &amp; White LEDs that can be turned on/off as desired.<br />
I made a 3D printed black cone insert that I stick in the front opening to block the light when I want to measure existing light without the LEDs interfering.</p>
]]></description><link>https://community.m5stack.com/post/28031</link><guid isPermaLink="true">https://community.m5stack.com/post/28031</guid><dc:creator><![CDATA[Glintor]]></dc:creator><pubDate>Sat, 25 Jan 2025 02:33:44 GMT</pubDate></item><item><title><![CDATA[Reply to [Product Revision] Color Sensor (U009) - Ability to turn off LEDs on Tue, 11 Jun 2024 18:08:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/holofloh" aria-label="Profile: holofloh">@<bdi>holofloh</bdi></a></p>
<p dir="auto">Using the INT is a good idea (I was thinking an extra IC), but now that you mention it, having both white &amp; UV could be useful to others as well.</p>
<p dir="auto">I shouldn't have put the word "spectrum", but rather (color) "temperature" (what I'm using the sensor for, roughly calculated from the RGB intensities). To truly read a spectral response would require a prism/grating and a linear monochromatic sensor (and calibration).</p>
]]></description><link>https://community.m5stack.com/post/25541</link><guid isPermaLink="true">https://community.m5stack.com/post/25541</guid><dc:creator><![CDATA[Zavyru]]></dc:creator><pubDate>Tue, 11 Jun 2024 18:08:00 GMT</pubDate></item><item><title><![CDATA[Reply to [Product Revision] Color Sensor (U009) - Ability to turn off LEDs on Tue, 04 Jun 2024 07:01:17 GMT]]></title><description><![CDATA[<p dir="auto">According to the schematic the LEDs are hard connected between VCC and GND (with a 1k Resistor in serie). It may be an option to misuse the sensors INT pin and its limit threshold settings to switch the LEDs on and off. It is a open-drain with a max of 20mA. Or spend an extra I2C output driver (one Output for white LED or more if you want different LED colors - deep blue or ultra violet may be helpful to identify e.g. fluorescence).<br />
Anyway, it will never be a spectrometer like device as there are only 3 colored sensors with a more or less wide spectral bandwith but still gaps between.</p>
]]></description><link>https://community.m5stack.com/post/25477</link><guid isPermaLink="true">https://community.m5stack.com/post/25477</guid><dc:creator><![CDATA[holofloh]]></dc:creator><pubDate>Tue, 04 Jun 2024 07:01:17 GMT</pubDate></item></channel></rss>
