<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Stick C Plus wont power on, but COM port exists]]></title><description><![CDATA[<p dir="auto">I left a speaker hat attached to an M5 StickC Plus, I'm not sure that's affected anything, but it seems to have drained the battery and now I cannot get it to power on.</p>
<p dir="auto">To fix it I have tried:</p>
<p dir="auto">[1] Attaching it to a PC via a USB cable. The COM port appears, I cannot upload code to it via the Arduino IDE. I get "Failed uploading: uploading error: exit status 2"</p>
<p dir="auto">[2] Using M5 Burner. When I attach the M5 Stick M5 Burner reports that it has "Found new device". However, I can't flash it via M5 Burner and I can't erase it via M5 Burner. When I try it says "A fatal error occurred, the COM port doesn't exist"</p>
<p dir="auto">[3] I have left it attached to 2 different chargers for 1 hour + each. Still no charge.</p>
<p dir="auto">[4] I have tried attaching 3 x AA batteries to the 5v In and GND pins on the top header row. No change.</p>
<p dir="auto">Is it completely dead? Any thoughts on what I can do to get it going again?</p>
]]></description><link>https://community.m5stack.com/topic/6560/m5-stick-c-plus-wont-power-on-but-com-port-exists</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 13:06:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6560.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Jun 2024 05:04:46 GMT</pubDate><ttl>60</ttl></channel></rss>
