<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need help to build a parking sensor]]></title><description><![CDATA[<p dir="auto">Hello, I´,m looking for two Ultrasonic sensors to be used as simple parking sensor (car under sensor yes/no is sufficient) to be integrated into home assistant. Preferred connection to Home Assistant via Wifi, power supply via USB power plug.</p>
<p dir="auto">I have more or less no technical knowledge in that area. looking for something like ESP32 for Home Assistant implementation.</p>
<p dir="auto">Can you recommend what I need, and do I need to solder anything? Do I need to install/use any complicated software other than home assistant?</p>
<p dir="auto">Thank you in advance</p>
]]></description><link>https://community.m5stack.com/topic/6578/need-help-to-build-a-parking-sensor</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 08:34:56 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6578.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 22 Jun 2024 17:41:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need help to build a parking sensor on Sun, 23 Jun 2024 07:13:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeyone" aria-label="Profile: JeyOne">@<bdi>JeyOne</bdi></a> Please take a look at the examples in UIFLow's project zone.<br />
As to home assistant, I'm sure someone knows about HA.</p>
]]></description><link>https://community.m5stack.com/post/25652</link><guid isPermaLink="true">https://community.m5stack.com/post/25652</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 23 Jun 2024 07:13:28 GMT</pubDate></item></channel></rss>
