<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stick C Plus 2 ENV III Hat]]></title><description><![CDATA[<p dir="auto">Hello everyone i have integrated the env iii hat into my m5stick c plus 2 and noticed that the measured temperature values of the sht30 as well as qmp6988 are clearly too high. is this due to the waste heat of the esp32? are there any solutions for this. otherwise this hat seems to be unnecessary, because the measured temperature does not match the reality in any way.</p>
]]></description><link>https://community.m5stack.com/topic/6618/m5stick-c-plus-2-env-iii-hat</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 05:06:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6618.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Jul 2024 07:58:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stick C Plus 2 ENV III Hat on Tue, 09 Jul 2024 10:01:40 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the information guys and the idea with the wire extension. I will give this a try. But i have to say the normal hy2.0 sensors like: <a href="https://shop.m5stack.com/products/env-iv-unit-with-temperature-humidity-air-pressure-sensor-sht40-bmp280" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/env-iv-unit-with-temperature-humidity-air-pressure-sensor-sht40-bmp280</a> are then the better choice compared to the HATs or?</p>
]]></description><link>https://community.m5stack.com/post/25788</link><guid isPermaLink="true">https://community.m5stack.com/post/25788</guid><dc:creator><![CDATA[ptrkx]]></dc:creator><pubDate>Tue, 09 Jul 2024 10:01:40 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stick C Plus 2 ENV III Hat on Tue, 09 Jul 2024 07:51:21 GMT]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/user/ptrkx" aria-label="Profile: ptrkx">@<bdi>ptrkx</bdi></a>,</p>
<p dir="auto">Yep, ESP32 heat can definitely mess with the readings. Those wire extensions robski mentioned are a great trick!  I've seen some folks use a small heatsink on the ESP32 too with good results.</p>
]]></description><link>https://community.m5stack.com/post/25785</link><guid isPermaLink="true">https://community.m5stack.com/post/25785</guid><dc:creator><![CDATA[mattarnold700]]></dc:creator><pubDate>Tue, 09 Jul 2024 07:51:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stick C Plus 2 ENV III Hat on Mon, 08 Jul 2024 14:20:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ptrkx" aria-label="Profile: ptrkx">@<bdi>ptrkx</bdi></a> said in <a href="/post/25781">M5Stick C Plus 2 ENV III Hat</a>:</p>
<p dir="auto">i have few ENV2 HATs and when tested with wire extension between M5Stick and HAT results were more accurate than when HAT fitted direct to unit.</p>
]]></description><link>https://community.m5stack.com/post/25782</link><guid isPermaLink="true">https://community.m5stack.com/post/25782</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 08 Jul 2024 14:20:09 GMT</pubDate></item></channel></rss>
