<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Boat computer with Bareboat Necessities OS on m5stack CoreMP135]]></title><description><![CDATA[<p dir="auto"><img src="https://raw.githubusercontent.com/bareboat-necessities/lysmarine_gen/coremp135_bookworm/img/bbn-on-coremp135.png" alt="Bareboat Necessities OS" class=" img-fluid img-markdown" /></p>
<p dir="auto">I’ve made Bareboat Necessities (BBN) Marine OS for CoreMP135 from m5stack.</p>
<p dir="auto">It’s free and open source system based on Debian Bookworm.</p>
<p dir="auto">CoreMP135 of BBN OS version includes:</p>
<li>SignalK</li>
<li>PyPilot</li>
<li>GPSd</li>
<li>Kplex</li>
<li>Canboat</li>
<li>Victron WEB UI</li>
<p dir="auto">BBN OS on CoreMP135 turns it into boat appliance able to communicate with N2K, NMEA 0183, PyPilot motor controller and IMU, Victron Cerbo MQTT.</p>
<p dir="auto">The CoreMP135 device loaded with BBN OS is practically plug and play. After initial boot you can just wire your boat devices via RS-485 or CAN and start using it. No configuration required.</p>
<p dir="auto">The documentation, source code and download links:</p>
<p dir="auto"><a href="https://github.com/bareboat-necessities/lysmarine_gen/tree/coremp135_bookworm" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bareboat-necessities/lysmarine_gen/tree/coremp135_bookworm</a></p>
<p dir="auto"><img src="https://raw.githubusercontent.com/bareboat-necessities/lysmarine_gen/coremp135_bookworm/img/bbn-coremp135.png" alt="Bareboat Necessities CoreMP135" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/6656/boat-computer-with-bareboat-necessities-os-on-m5stack-coremp135</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:09:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6656.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Jul 2024 00:45:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Boat computer with Bareboat Necessities OS on m5stack CoreMP135 on Wed, 09 Oct 2024 15:48:40 GMT]]></title><description><![CDATA[<p dir="auto">The latest image now has flutter-ui boatinstrument interface on hdmi port.</p>
<p dir="auto">SignalK is available via web ui. As well as FreeboardSK and KIP dashboard.</p>
<p dir="auto">After two reboots SD card partition is resized to max available space.</p>
<p dir="auto">NMEA 2000 interface is ready. All you need to do is connect two wires.</p>
<p dir="auto">Most of USB gps devices are recognized on plugging in automatically.</p>
<p dir="auto">Image includes Victron Web UI as well.</p>
<p dir="auto">Console access is available via USB-C port at<br />
115200 bauds.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://community.m5stack.com/post/26668</link><guid isPermaLink="true">https://community.m5stack.com/post/26668</guid><dc:creator><![CDATA[mgrouch]]></dc:creator><pubDate>Wed, 09 Oct 2024 15:48:40 GMT</pubDate></item></channel></rss>
