<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m5stick c plus 2 not turning on]]></title><description><![CDATA[<p dir="auto">recently i bought an m5stick c plus 2 and i downloaded nemo<br />
it was working normally but 2 days later my stick wasnt booting</p>
<p dir="auto">when i hold the on/off button appears an green light but the screen doesnt turn on</p>
<p dir="auto">when i try to burn something in the m5burner this is what happens:</p>
<p dir="auto">Detecting chip type...<br />
ESP32<br />
Chip is ESP32-PICO-V3-02 (revision v3.0)<br />
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None<br />
Crystal is 40MHz<br />
MAC: e8:9f:6d:32:e2:58<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Changing baud rate to 1500000<br />
Changed.<br />
WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.<br />
Warning: Could not auto-detect Flash size (FlashID=0xffffff, SizeID=0xff), defaulting to 4MB<br />
Flash will be erased from 0x00000000 to 0x00289fff...<br />
Compressed 2660976 bytes to 1589191...</p>
<p dir="auto">A fatal error occurred: Packet content transfer stopped (received 8 bytes)</p>
<p dir="auto">help pls</p>
]]></description><link>https://community.m5stack.com/topic/6661/m5stick-c-plus-2-not-turning-on</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 07:44:47 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6661.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Jul 2024 20:10:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m5stick c plus 2 not turning on on Mon, 09 Dec 2024 20:59:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> what do you mean "connect wire from G0 to GND"?</p>
]]></description><link>https://community.m5stack.com/post/27508</link><guid isPermaLink="true">https://community.m5stack.com/post/27508</guid><dc:creator><![CDATA[eugenHypr]]></dc:creator><pubDate>Mon, 09 Dec 2024 20:59:51 GMT</pubDate></item><item><title><![CDATA[Reply to m5stick c plus 2 not turning on on Sun, 04 Aug 2024 09:13:51 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/cmcrrr" aria-label="Profile: cmcrrr">@<bdi>cmcrrr</bdi></a></p>
<p dir="auto">you might want to force M5StickCPlus2 into download mode manually. Below are the steps:</p>
<li>disconnect USB</li>
<li>press and hold PWR button until green LED lights up, then release button</li>
<li>connect a wire from G0 to GND</li>
<li>attach USB</li>
<li>remove wire<br />
--&gt; M5StickCPlus2 is now in download mode.</li>
<li>Use M5Burner to erase or flash something.</li>
]]></description><link>https://community.m5stack.com/post/25993</link><guid isPermaLink="true">https://community.m5stack.com/post/25993</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 04 Aug 2024 09:13:51 GMT</pubDate></item><item><title><![CDATA[Reply to m5stick c plus 2 not turning on on Mon, 29 Jul 2024 06:58:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cmcrrr" aria-label="Profile: cmcrrr">@<bdi>cmcrrr</bdi></a> can you try to use M5Burner and go for ERASE before burn? Or just try to load EasyLoader file for M5Stack? or just load siple sketch from Arduino?</p>
]]></description><link>https://community.m5stack.com/post/25942</link><guid isPermaLink="true">https://community.m5stack.com/post/25942</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 29 Jul 2024 06:58:37 GMT</pubDate></item><item><title><![CDATA[Reply to m5stick c plus 2 not turning on on Sat, 27 Jul 2024 15:56:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cmcrrr" aria-label="Profile: cmcrrr">@<bdi>cmcrrr</bdi></a> Maybe the Nemo hacking software hacked you?<br />
This happens so often I am starting to suspect that Nemo has itself been hacked.<br />
You should contact the wider Nemo hacking community. and see any fellow hackers are experience this problem.</p>
]]></description><link>https://community.m5stack.com/post/25937</link><guid isPermaLink="true">https://community.m5stack.com/post/25937</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sat, 27 Jul 2024 15:56:08 GMT</pubDate></item></channel></rss>
