<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[M5Stack Core2 v1.1] COM port not found]]></title><description><![CDATA[<h1>Problem</h1>
<p dir="auto">OS: MacOS 13.6.3 (intel)<br />
Application: M5Burner (latest version, on Aug 4)</p>
<p dir="auto">The serial port cann't display in M5Burner application.</p>
<h1>Steps taken</h1>
<li>
<p dir="auto">Tried different IDEs, but nothing worked.</p>
</li>
<li>
<p dir="auto">Switched USB cables, yet COM port was still not visible.</p>
</li>
<li>
<p dir="auto">Attempt to turn the USB lead upside down when plugging into the device without success.</p>
</li>
<li>
<p dir="auto">I quickly press the boot button and Serial port was able to display, but soon disappeared. I seize the opportunity to click "erase" button, but it still didn't work and show the following error.</p>
</li>
<p dir="auto"><strong>Error message:</strong></p>
<pre><code>Erase Flash
esptool.py v4.7-dev
Serial port /dev/tty.usbserial-58640309931
A fatal error occurred: Could not open /dev/tty.usbserial-58640309931, the port doesn't exist
<h1>Solution:</h1>
<p dir="auto">After removing the base and battery, I tried the 4th option and successfully erased the firmware!!!</p>
<h1>Question:</h1>
<p dir="auto">What are the possible casues of the issuse?<br />
How to burn the fireware correctly?<br />
What steps should be avoid?</p>
]]></description><link>https://community.m5stack.com/topic/6675/m5stack-core2-v1-1-com-port-not-found</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 22:36:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6675.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Aug 2024 07:48:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [M5Stack Core2 v1.1] COM port not found on Sun, 18 Aug 2024 10:00:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>  Thank you soo much!<br />
I turned off the VPN, and then it worked.</p>
]]></description><link>https://community.m5stack.com/post/26152</link><guid isPermaLink="true">https://community.m5stack.com/post/26152</guid><dc:creator><![CDATA[surprise]]></dc:creator><pubDate>Sun, 18 Aug 2024 10:00:33 GMT</pubDate></item><item><title><![CDATA[Reply to [M5Stack Core2 v1.1] COM port not found on Sun, 04 Aug 2024 16:11:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/surprise" aria-label="Profile: surprise">@<bdi>surprise</bdi></a> Have you installed the correct USB driver and made sure that its working?</p>
]]></description><link>https://community.m5stack.com/post/25994</link><guid isPermaLink="true">https://community.m5stack.com/post/25994</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 04 Aug 2024 16:11:36 GMT</pubDate></item></channel></rss>
