<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Error] Get MAC failed in m5Burner]]></title><description><![CDATA[<p dir="auto">OS: MacOS 13.6.1<br />
App: m5Burner Version 3.0.0 (3.0.0)<br />
Product: M5 stack Core2 v1.1</p>
<p dir="auto">When I click "Start" Button, showing the message:<br />
<img src="/assets/uploads/files/1722914270207-2bc27c36-b6c8-4b6d-92e2-d148f032321c-image.png" alt="2bc27c36-b6c8-4b6d-92e2-d148f032321c-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/6682/error-get-mac-failed-in-m5burner</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 19:36:04 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6682.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Aug 2024 03:18:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Error] Get MAC failed in m5Burner on Sat, 07 Jun 2025 05:23:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/boomvalt" aria-label="Profile: Boomvalt">@<bdi>Boomvalt</bdi></a> Xcode is OSX's dev environment and is needed for some low level functions needed for hardware programming even if you are not directly using it.</p>
]]></description><link>https://community.m5stack.com/post/29179</link><guid isPermaLink="true">https://community.m5stack.com/post/29179</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 07 Jun 2025 05:23:35 GMT</pubDate></item><item><title><![CDATA[Reply to [Error] Get MAC failed in m5Burner on Thu, 05 Jun 2025 10:12:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slartibartfast" aria-label="Profile: Slartibartfast">@<bdi>Slartibartfast</bdi></a> why use xcode?</p>
]]></description><link>https://community.m5stack.com/post/29173</link><guid isPermaLink="true">https://community.m5stack.com/post/29173</guid><dc:creator><![CDATA[Boomvalt]]></dc:creator><pubDate>Thu, 05 Jun 2025 10:12:26 GMT</pubDate></item><item><title><![CDATA[Reply to [Error] Get MAC failed in m5Burner on Sun, 12 Jan 2025 06:58:44 GMT]]></title><description><![CDATA[<p dir="auto">Hey everyone!</p>
<p dir="auto">I know this is old but if someone stubles across this like I did here's the fix...<br />
I'm running MacOS Sequoia 15.2. To get rid of this error you have to do a couple of things:</p>
<li>Install <a href="https://apps.apple.com/us/app/xcode/id497799835?mt=12" target="_blank" rel="noopener noreferrer nofollow ugc">xcode</a> from the app store.</li>
<li><em>VERY IMPORTANT</em> Open xcode from your Applications menu and answer all of the questions (install the version for MacOS). If you don't do this xcode isn't installed even though you installed it from the app store.</li>
<li>Download and install the appropriate driver. For most it's <a href="https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/drivers/CP210x_VCP_MacOS.zip" target="_blank" rel="noopener noreferrer nofollow ugc">CP210x</a>. I did a reboot after installation</li>
<li>Download <a href="https://m5burner-cdn.m5stack.com/app/M5Burner-v3-mac-x64.dmg" target="_blank" rel="noopener noreferrer nofollow ugc">m5burner</a> and install it.</li>
<p dir="auto">This worked for me. I noticed the first time I did a burn it took a long time, but part of that is I was using UIFlow2.0 with all of the account binding stuff.</p>
<p dir="auto">Hope this helps!</p>
]]></description><link>https://community.m5stack.com/post/27860</link><guid isPermaLink="true">https://community.m5stack.com/post/27860</guid><dc:creator><![CDATA[Slartibartfast]]></dc:creator><pubDate>Sun, 12 Jan 2025 06:58:44 GMT</pubDate></item><item><title><![CDATA[Reply to [Error] Get MAC failed in m5Burner on Wed, 28 Aug 2024 05:07:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cchakons" aria-label="Profile: cchakons">@<bdi>cchakons</bdi></a> The error message you have implies that you have the wrong firmware selected for the stick Cplus2</p>
]]></description><link>https://community.m5stack.com/post/26251</link><guid isPermaLink="true">https://community.m5stack.com/post/26251</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 28 Aug 2024 05:07:56 GMT</pubDate></item><item><title><![CDATA[Reply to [Error] Get MAC failed in m5Burner on Tue, 27 Aug 2024 22:13:11 GMT]]></title><description><![CDATA[<p dir="auto">I'm having the same error when I use the m5Burner. I did install the drivers, and when I use <a href="https://uiflow2.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://uiflow2.m5stack.com/</a> and hit run, I can see some log messages coming from the m5stickC plus2 when I press the button in the demo app, so the read operation seems to be working. But if I click burn in <a href="http://uiflow2.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">uiflow2.m5stack.com</a> doesnt work either.</p>
<p dir="auto">I also got this error message earlier:<br />
new m5stack: Failed to write to target RAM (result was 01070000)</p>
<p dir="auto">I'm using Mac OS Monterrey (12.7.4 (21H1123)), Intel CPU</p>
<p dir="auto">I've tried the installation of the drivers several times, without any luck getting the m5burner working.</p>
]]></description><link>https://community.m5stack.com/post/26248</link><guid isPermaLink="true">https://community.m5stack.com/post/26248</guid><dc:creator><![CDATA[cchakons]]></dc:creator><pubDate>Tue, 27 Aug 2024 22:13:11 GMT</pubDate></item><item><title><![CDATA[Reply to [Error] Get MAC failed in m5Burner on Tue, 06 Aug 2024 03:50:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/surprise" aria-label="Profile: surprise">@<bdi>surprise</bdi></a> Have you installed the USB driver?<br />
Are you using a good known to be working USBC Data cable ?</p>
]]></description><link>https://community.m5stack.com/post/26012</link><guid isPermaLink="true">https://community.m5stack.com/post/26012</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 06 Aug 2024 03:50:57 GMT</pubDate></item></channel></rss>
