<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fire with UIFlow2]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">i'm new to the M5Stack universe. I got my Fire 2.7 today and tried to upload the UIFlow2 Firmware for fire.<br />
Flashing is working well (i also get a success message, hash was verified, ....), but the device is dead after flashing.</p>
<p dir="auto">On the serial monitor i can see that something is corrupted:</p>
<pre><code>Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:4912
load:0x40078000,len:15532
load:0x40080400,len:3696
entry 0x400805e0
[0;31mE (1766) esp_psram: SPI SRAM memory test fail. 347/131072 writes failed, first @ 3F80B420
[0m
[0;31mE (1766) cpu_start: External RAM failed memory test![0m
abort() was called at PC 0x40081ae1 on core 0
Backtrace: 0x40082605:0x3ffe3b90 0x40098181:0x3ffe3bb0 0x4009ba71:0x3ffe3bd0 0x40081ae1:0x3ffe3c40 0x40079630:0x3ffe3c80 |&lt;-CORRUPTED
<p dir="auto">I also tried different version, but without any success. Is there any possibility to work with the Fire and UIFlow2?</p>
<p dir="auto">Thank you very much!</p>
<p dir="auto">Best,<br />
André</p>
]]></description><link>https://community.m5stack.com/topic/6685/fire-with-uiflow2</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 19:36:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6685.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Aug 2024 19:21:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fire with UIFlow2 on Thu, 08 Aug 2024 19:56:40 GMT]]></title><description><![CDATA[<p dir="auto">@a-wussow Glad to see you got it working again.</p>
]]></description><link>https://community.m5stack.com/post/26036</link><guid isPermaLink="true">https://community.m5stack.com/post/26036</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 08 Aug 2024 19:56:40 GMT</pubDate></item><item><title><![CDATA[Reply to Fire with UIFlow2 on Thu, 08 Aug 2024 09:34:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thanks for your response.<br />
Yes, i used M5Burner and also tried erase before burning.<br />
I selected "UIFlow2.0 Fire".</p>
<p dir="auto">But in the meantime i worked with Arduino IDE and tried it again. After flashing with Arduino, Erasing with M5 Burner and Flashing again with M5 Burner its now working. Strange ...</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://community.m5stack.com/post/26030</link><guid isPermaLink="true">https://community.m5stack.com/post/26030</guid><dc:creator><![CDATA[a.wussow]]></dc:creator><pubDate>Thu, 08 Aug 2024 09:34:06 GMT</pubDate></item><item><title><![CDATA[Reply to Fire with UIFlow2 on Thu, 08 Aug 2024 04:53:21 GMT]]></title><description><![CDATA[<p dir="auto">@a-wussow Did you use M5Burner?<br />
Did you erase before burning?<br />
Did you select the correct firmware version?</p>
]]></description><link>https://community.m5stack.com/post/26028</link><guid isPermaLink="true">https://community.m5stack.com/post/26028</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 08 Aug 2024 04:53:21 GMT</pubDate></item></channel></rss>
