<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5CoreS3 Camera Pinout for use with ESP32 CameraWebServer example]]></title><description><![CDATA[<p dir="auto">Has anyone gotten the GC308 camera on the M5CoreS3 working with the ESP32 CameraWebServer example?  If so, what configuration did you use?  I'm compiling with the Arduino IDE 2.3.2 and tried using the pinout from the M5CoreS3 library Basic-&gt;Camera example that didn't work.</p>
]]></description><link>https://community.m5stack.com/topic/6691/m5cores3-camera-pinout-for-use-with-esp32-camerawebserver-example</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:37:52 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6691.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Aug 2024 23:41:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5CoreS3 Camera Pinout for use with ESP32 CameraWebServer example on Tue, 13 Aug 2024 21:00:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a></p>
<p dir="auto">Hi Felix,</p>
<p dir="auto">I discovered that the problem with the stream not starting is related to poor WiFi performance.  It works when I put the M5CoreS3 near my WiFi access point.</p>
<p dir="auto">From the comments in your program source, I guess you don't expect most of the features other than streaming to work.</p>
<p dir="auto">I had hoped that resize and face detect might work.  V-Flip, H-Mirror and Save seem to work.</p>
<p dir="auto">Thanks, it's a place to start.</p>
<p dir="auto">Ralph</p>
]]></description><link>https://community.m5stack.com/post/26078</link><guid isPermaLink="true">https://community.m5stack.com/post/26078</guid><dc:creator><![CDATA[ralphjy]]></dc:creator><pubDate>Tue, 13 Aug 2024 21:00:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5CoreS3 Camera Pinout for use with ESP32 CameraWebServer example on Mon, 12 Aug 2024 05:48:51 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ralphjy" aria-label="Profile: ralphjy">@<bdi>ralphjy</bdi></a></p>
<p dir="auto">in the web-interface have you clicked the red button to start the stream?</p>
<p dir="auto">I think I've seen those partition errors sometimes as well, but so far they did not prevent the stream from working.</p>
]]></description><link>https://community.m5stack.com/post/26061</link><guid isPermaLink="true">https://community.m5stack.com/post/26061</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 12 Aug 2024 05:48:51 GMT</pubDate></item><item><title><![CDATA[Reply to M5CoreS3 Camera Pinout for use with ESP32 CameraWebServer example on Sun, 11 Aug 2024 20:11:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a>,</p>
<p dir="auto">Both of those partition files allowed me to compile and upload, but both have a different runtime partition error.  I can connect to the webserver, but there isn't any stream.  Not sure if that is caused by the partition errors.</p>
<p dir="auto">With the original partitions,csv:<br />
12:02:12.823 -&gt; E (591) esp_core_dump_flash: No core dump partition found!<br />
12:02:14.972 -&gt; hello<br />
12:02:15.235 -&gt; Camera init ok.<br />
12:02:15.268 -&gt; Camera sensor found.<br />
12:02:15.268 -&gt; Camera PID: 0x9b GC0308_PID: 0x9b.<br />
12:02:15.302 -&gt; cam_hal: EV-VSYNC-OVF<br />
12:02:15.807 -&gt; .....................................<br />
12:02:33.807 -&gt; WiFi connected<br />
12:02:33.847 -&gt; Camera Ready! Use '<a href="http://10.0.0.139" target="_blank" rel="noopener noreferrer nofollow ugc">http://10.0.0.139</a>' to connect</p>
<p dir="auto">With the 8MB APP partitions.csv:<br />
11:35:14.013 -&gt; hello<br />
11:35:14.013 -&gt; Camera init ok.<br />
11:35:14.013 -&gt; Camera sensor found.<br />
11:35:14.013 -&gt; Camera PID: 0x9b GC0308_PID: 0x9b.<br />
11:35:14.013 -&gt; cam_hal: EV-VSYNC-OVF<br />
11:35:14.013 -&gt; ......................................................<br />
11:35:36.199 -&gt; WiFi connected<br />
11:35:36.199 -&gt; [0;31mE (30217) MFN: Partition Not found[0m<br />
11:35:36.199 -&gt; [0;31mE (30217) MFN: Please Set the Partition[0m<br />
11:35:36.199 -&gt; Camera Ready! Use '<a href="http://10.0.0.139" target="_blank" rel="noopener noreferrer nofollow ugc">http://10.0.0.139</a>' to connect</p>
<p dir="auto">But in either case there is no stream or image.</p>
<p dir="auto">If it is working for you, I must just have some issue with my setup.  I'll admit that never tried to set up partitions before.  I don't even see the M5CoreS3 n the boards.txt file.</p>
]]></description><link>https://community.m5stack.com/post/26060</link><guid isPermaLink="true">https://community.m5stack.com/post/26060</guid><dc:creator><![CDATA[ralphjy]]></dc:creator><pubDate>Sun, 11 Aug 2024 20:11:09 GMT</pubDate></item><item><title><![CDATA[Reply to M5CoreS3 Camera Pinout for use with ESP32 CameraWebServer example on Sun, 11 Aug 2024 10:54:11 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ralphjy" aria-label="Profile: ralphjy">@<bdi>ralphjy</bdi></a></p>
<p dir="auto">hmm, no, I am not using any special partition scheme. Maybe try the one from the original code? See <a href="https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/partitions.csv" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">Or this one <a href="https://github.com/espressif/arduino-esp32/blob/master/tools/partitions/max_app_8MB.csv" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/26054</link><guid isPermaLink="true">https://community.m5stack.com/post/26054</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 11 Aug 2024 10:54:11 GMT</pubDate></item><item><title><![CDATA[Reply to M5CoreS3 Camera Pinout for use with ESP32 CameraWebServer example on Sun, 11 Aug 2024 05:45:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a></p>
<p dir="auto">Thanks - I just tried it and it ran out of storage space after compiling.</p>
<p dir="auto">"Sketch uses 3259241 bytes (103%) of program storage space. Maximum is 3145728 bytes.<br />
Global variables use 74760 bytes (22%) of dynamic memory, leaving 252920 bytes for local variables. Maximum is 327680 bytes."</p>
<p dir="auto">I've been using the Partition Scheme: "16M Flash (3MB APP/9.9MB FATFS)"</p>
<p dir="auto">Are you using a Custom Scheme?</p>
]]></description><link>https://community.m5stack.com/post/26051</link><guid isPermaLink="true">https://community.m5stack.com/post/26051</guid><dc:creator><![CDATA[ralphjy]]></dc:creator><pubDate>Sun, 11 Aug 2024 05:45:41 GMT</pubDate></item><item><title><![CDATA[Reply to M5CoreS3 Camera Pinout for use with ESP32 CameraWebServer example on Sun, 11 Aug 2024 05:28:36 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ralphjy" aria-label="Profile: ralphjy">@<bdi>ralphjy</bdi></a></p>
<p dir="auto">please find my CameraWebServer adaption for M5CoreS3 <a href="https://github.com/felmue/MyM5StackExamples/tree/main/M5CoreS3/CamWebServer" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/26050</link><guid isPermaLink="true">https://community.m5stack.com/post/26050</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 11 Aug 2024 05:28:36 GMT</pubDate></item></channel></rss>
