<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[H-Bridge PWM signal to Papst 4412 FGMPR Vent doesent spin Backward at 60% PWM ??]]></title><description><![CDATA[<p dir="auto">I´m new here, hello.<br />
Can someone help me out how to use a H-Bridge to correct regulate the 0-40% and 60-100 % PWM Signal.<br />
This Vent has the special Possiblility to Spin in both Directions, vorward and Backward with the correct PWM Signal.<br />
Here is the Sheet to it:<br />
<a href="https://docs.rs-online.com/d48e/A700000006464999.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.rs-online.com/d48e/A700000006464999.pdf</a><br />
It sounds easy to just use 40% or 60% PWM Rate to get the Result.<br />
But sadly, it doesent do what i want it to do.<br />
I ended up now with sending the PWM signal, vs. not Pluging the PWM Signal at all.<br />
This lets the Fan spin in the Opposit direction.<br />
It´s confusing, i cannot understand what the Problem here is but it works now how i wanted it.</p>
<p dir="auto">But what do i wrong ? Is it the wiring or the Setting, or the wrong Module ?<br />
I need a PWM Module that can work in on a i2c A Hub, for the Possibility to regulate 4 Fans seperate with Individual settings.<br />
Any recommendations for this task, what i can use for it ?</p>
]]></description><link>https://community.m5stack.com/topic/6694/h-bridge-pwm-signal-to-papst-4412-fgmpr-vent-doesent-spin-backward-at-60-pwm</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 12:47:45 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6694.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Aug 2024 20:21:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to H-Bridge PWM signal to Papst 4412 FGMPR Vent doesent spin Backward at 60% PWM ?? on Fri, 23 Aug 2024 07:06:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teastain" aria-label="Profile: teastain">@<bdi>teastain</bdi></a> Hi teastain, thank you for your reply with this Informations. Sadly i thougt i need this H bridges, and bought them all. So now i use them with the possibility up to 10000 frequency. One Set of Vents would need 25000 frequency, but they work also with 10000. The others only need 2000-4000 frequency, and happy with the value it can deliver. And i have no idea how to use 5 set of Fan´s with the onboard PWM and different Values.<br />
The Hub-B can deliver PWM, but i cannot choose the frequency, so i not try to use this device, because lower frequencys at 2000-5000 with the 25000 frequency Fans produce very noisy Fan Sounds. But at 10000 it is ok to hear.</p>
<p dir="auto">On the End, i´m happy the Fans i have can be used with the M5stack H Bridge Units.</p>
<p dir="auto">The next i need to do is, <strong>how to use Servos, to Automatically set the height of the Lamp</strong>.<br />
<strong>But how i can Stop and Hold a Servo, also without a Power Source to hold the weight ?</strong><br />
Are there some M5stack Units and Servos i can use with a weight of <strong>2-3kg ?</strong><br />
They should lift and securely stop lifting in a <strong>Range of 1 Meter</strong>.<br />
I looked up some RC Winds and a Servo Unit, but the Most of them have no rachet stopper, and for now i have no idea what devices i can use easily for this task.</p>
]]></description><link>https://community.m5stack.com/post/26203</link><guid isPermaLink="true">https://community.m5stack.com/post/26203</guid><dc:creator><![CDATA[NoobCheck1]]></dc:creator><pubDate>Fri, 23 Aug 2024 07:06:42 GMT</pubDate></item><item><title><![CDATA[Reply to H-Bridge PWM signal to Papst 4412 FGMPR Vent doesent spin Backward at 60% PWM ?? on Mon, 12 Aug 2024 20:39:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noobcheck1" aria-label="Profile: NoobCheck1">@<bdi>NoobCheck1</bdi></a> Connect the power and grounds to a sufficient power supply. No H bridge needed!<br />
You fan works like a M5Stack 360 deg (Continuous)  RC hobby servo.<br />
Here is code.<br />
<a href="https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Accessory/ServoKit180_360/Arduino/ServoKit180_360" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Accessory/ServoKit180_360/Arduino/ServoKit180_360</a><br />
I have not tried it but I have done 360 servos...and this is the M5Stack 360 example.<br />
And a PbHub should work.</p>
]]></description><link>https://community.m5stack.com/post/26063</link><guid isPermaLink="true">https://community.m5stack.com/post/26063</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Mon, 12 Aug 2024 20:39:12 GMT</pubDate></item></channel></rss>
