<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[why is my m5stickcplus2 not turning on]]></title><description><![CDATA[<p dir="auto">why is my m5stickcplus2 not turning on i dont know whats wrong with it</p>
]]></description><link>https://community.m5stack.com/topic/6708/why-is-my-m5stickcplus2-not-turning-on</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 08:34:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6708.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Aug 2024 05:53:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to why is my m5stickcplus2 not turning on on Fri, 16 Aug 2024 17:08:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stunt_bot" aria-label="Profile: stunt_bot">@<bdi>stunt_bot</bdi></a> it’s hard to say, what have you tried?</p>
]]></description><link>https://community.m5stack.com/post/26122</link><guid isPermaLink="true">https://community.m5stack.com/post/26122</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 16 Aug 2024 17:08:27 GMT</pubDate></item><item><title><![CDATA[Reply to why is my m5stickcplus2 not turning on on Fri, 16 Aug 2024 12:40:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stunt_bot" aria-label="Profile: stunt_bot">@<bdi>stunt_bot</bdi></a> If you don't know, HOW should we?</p>
<p dir="auto">There are a few options:</p>
<li>Battery is empty</li>
<li>No firmware flashed</li>
<li>Firmware is flashed, but enters wrong mode (no Python-script to load)</li>
<p dir="auto">To troubleshoot:'</p>
<li>connect the device to the computer with a cable.</li>
<li>Install drivers, if necessary. Link: <a href="https://docs.m5stack.com/en/download" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/download</a></li>
<li>Maybe it is necessary to restart the comuter at this point.</li>
<li>Open a browser and go to: <a href="https://uiflow2.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://uiflow2.m5stack.com/</a> and login.</li>
<p dir="auto"><img src="/assets/uploads/files/1723811182589-f456fa5d-00a4-409c-a791-78a9d0c70aa9-image.png" alt="f456fa5d-00a4-409c-a791-78a9d0c70aa9-image.png" class=" img-fluid img-markdown" /></p>
<li>Your browser should ask you to connect to a serial device. Select the right COM-Port.</li>
<li>and then a consolewindow should start.</li>
<li>Look at the output on that window.</li>
<p dir="auto">If the console window tells you something like UIFlow, bla bla, then maybe you neet to upload a python file OR flash another firmware (depending on your needs)</p>
<p dir="auto">If the console window stays blank, uh oh! I don't know! Maybe you have erased previousely installed firmware and need to reflash it.</p>
<p dir="auto">Maybe you need to flash a firmware with the M5 Burner available at: <a href="https://docs.m5stack.com/en/uiflow/m5burner/intro" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/uiflow/m5burner/intro</a></p>
<p dir="auto">I hope I could help a bit.</p>
<p dir="auto">S B</p>
]]></description><link>https://community.m5stack.com/post/26120</link><guid isPermaLink="true">https://community.m5stack.com/post/26120</guid><dc:creator><![CDATA[sonderBUILDS]]></dc:creator><pubDate>Fri, 16 Aug 2024 12:40:07 GMT</pubDate></item></channel></rss>
