<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Arduino Export binary names changed (m5stick_c_plus to m5stack_stickc_plus) why?]]></title><description><![CDATA[<p dir="auto">I've been using the export binary from Arduino for a couple years. These are put on a server so an OTA can occur.</p>
<p dir="auto">To my surprise, I made some changes, repeated my process - but the update never happened.</p>
<p dir="auto">That's when I found out the name of the binary file was changed from:<br />
<strong>m5stick_c_plus</strong> to   <strong>m5stack_stickc_plus</strong></p>
<p dir="auto">I haven't found any documentation on the name of the binary, but I assume it related to the board (and mine is still: <strong>M5StickCPlus</strong>).</p>
<p dir="auto">I had been using library <strong>2.0.4</strong> but then upgraded to <strong>2.0.7</strong><br />
and now I see the version changed to: <strong>0.4.3</strong><br />
And the web page says to use the M5Unified version. For me that's<br />
a bridge too far right now.</p>
<p dir="auto">Arduion is version 1.8.19</p>
<p dir="auto">Is there any documentation on the versions and how the binary names are created? I did just see this (thanks). <a href="https://docs.m5stack.com/en/platform" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/platform</a></p>
<p dir="auto">I especially need to have a binary that is the same memory configuration as my 2.0.4 M5 and ESP32 since the OTA has to work for 100's of installed versions.</p>
<p dir="auto">thanks.</p>
]]></description><link>https://community.m5stack.com/topic/6722/arduino-export-binary-names-changed-m5stick_c_plus-to-m5stack_stickc_plus-why</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 07:22:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6722.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Aug 2024 22:47:26 GMT</pubDate><ttl>60</ttl></channel></rss>
