<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hardware selection advice is needed to control 16 servos independently]]></title><description><![CDATA[<p dir="auto">I was trying to look at the documentation and search this forum, but  I am not sure about the information I found.<br />
I am looking for a hardware that has a display and an sd card slot and can control 16 servos independently.<br />
I was looking at the M5stack core s3 se, but it is not clear for me from the documentation how many i/o pins I can use. On the schematic diagram I can only see three GPIO pins (G5, G6, G7). Are these the only three that I can use?<br />
If yes, is there another controller that I can use, or is there an i/o extender that can connect to the core s3?<br />
Sorry about the basic question. I am new to microcontrollers, I want to make sure that I am looking at the correct hardware for my goal before I buy it.</p>
]]></description><link>https://community.m5stack.com/topic/6739/hardware-selection-advice-is-needed-to-control-16-servos-independently</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 12:22:38 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6739.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 Aug 2024 03:31:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Hardware selection advice is needed to control 16 servos independently on Thu, 29 Aug 2024 15:28:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robski" aria-label="Profile: robski">@<bdi>robski</bdi></a><br />
Perfect, thank you very much.<br />
Can you please confirm that I understand this correctly?</p>
<li>
<p dir="auto">The <a href="https://shop.m5stack.com/products/m5stack-cores3-se-iot-controller-w-o-battery-bottom" target="_blank" rel="noopener noreferrer nofollow ugc">M5stack core s3 se</a> is compatible with the <a href="https://shop.m5stack.com/products/servo2-module-16-channels-13-2-pca9685" target="_blank" rel="noopener noreferrer nofollow ugc">16 channel servo2 module</a></p>
</li>
<li>
<p dir="auto">I need an external 6-12 volt power supply for the servo module</p>
</li>
<li>
<p dir="auto">Do I also need a separate power supply for the controller, or can the controller get power from the servo? If I do need a power supply, can I use one of the battery bottoms, like for example <a href="https://shop.m5stack.com/products/din-base-with-500mah-battery" target="_blank" rel="noopener noreferrer nofollow ugc">the din base</a>?</p>
</li>
<p dir="auto">And one last question, which probably should be in a separate thread. Is there a similar module for turning relays on/off (or can these PWM channels be used for this instead of controlling servos)? I could find the <a href="https://shop.m5stack.com/products/4-channel-relay-13-2-module-v1-1-stm32f030" target="_blank" rel="noopener noreferrer nofollow ugc">relay module</a>, but that is only 4 relays and I need 16.</p>
<p dir="auto">Again, sorry about the basic questions. I have a project in mind (a computer aided 16  shaft loom) that needs moving 16 harnesses up/down. I need 16 channels to control these movements. This can be done using servos or using solenoids.</p>
]]></description><link>https://community.m5stack.com/post/26270</link><guid isPermaLink="true">https://community.m5stack.com/post/26270</guid><dc:creator><![CDATA[fbeleznay]]></dc:creator><pubDate>Thu, 29 Aug 2024 15:28:12 GMT</pubDate></item><item><title><![CDATA[Reply to Hardware selection advice is needed to control 16 servos independently on Thu, 29 Aug 2024 12:45:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fbeleznay" aria-label="Profile: fbeleznay">@<bdi>fbeleznay</bdi></a><br />
<a href="https://docs.m5stack.com/en/module/servo" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/module/servo</a><br />
<a href="https://shop.m5stack.com/products/8-channel-servo-driver-unit-stm32f030" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/8-channel-servo-driver-unit-stm32f030</a><br />
<a href="https://shop.m5stack.com/products/servo2-module-16-channels-13-2-pca9685" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/servo2-module-16-channels-13-2-pca9685</a></p>
]]></description><link>https://community.m5stack.com/post/26269</link><guid isPermaLink="true">https://community.m5stack.com/post/26269</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Thu, 29 Aug 2024 12:45:54 GMT</pubDate></item></channel></rss>
