<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Not Connecting to Wifi - First Setup]]></title><description><![CDATA[<p dir="auto">Trying to setup my new M5Stack (Core) for the first time; I'm at the Wifi setup point, but it keeps failing to connect to my local Wifi;<br />
<em>LCD initializing...<br />
Done!<br />
WiFi AP WebServer Start!<br />
Connect to Wifi SSID:M5Stack-a00d<br />
And connect to esp via your web browser (like 192.168.4.1)<br />
listening on ('0.0.0.0', 80)<br />
{'ssid': 'XXX+2.4G', 'password': 'XXXXXXXXXX'}<br />
M5Stack Core try to connect WiFi: SSID:XXX+2.4G PASSWD:XXXXXXXXXX network...<br />
.....................................................................................................<br />
Problem. Not Connected to :XXX+2.4G</em></p>
<p dir="auto">It doesn't even detect the 5Ghz connection. And won't connected to the 2.4Ghz wifi</p>
]]></description><link>https://community.m5stack.com/topic/675/not-connecting-to-wifi-first-setup</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 11:17:00 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/675.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Feb 2019 16:58:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Not Connecting to Wifi - First Setup on Thu, 21 Feb 2019 16:16:11 GMT]]></title><description><![CDATA[<p dir="auto">I had the same problem. But I did decide to rename all my APs and every device connected. 30 minutes later, still can't get a device code, and it seems like it got stuck booting into the "Press next for instructions" screen, so I can't change the wifi if I wanted to :(</p>
]]></description><link>https://community.m5stack.com/post/3111</link><guid isPermaLink="true">https://community.m5stack.com/post/3111</guid><dc:creator><![CDATA[Mikey Wetzel]]></dc:creator><pubDate>Thu, 21 Feb 2019 16:16:11 GMT</pubDate></item><item><title><![CDATA[Reply to Not Connecting to Wifi - First Setup on Fri, 15 Feb 2019 09:53:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slumnit" aria-label="Profile: slumnit">@<bdi>slumnit</bdi></a> said in <a href="/post/3033">Not Connecting to Wifi - First Setup</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> well as I mentioned in the response above the one to you, I had updated the firmware according to the video on the <a href="http://M5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">M5stack.com</a> website; as the only video available that walks you through the process, has you install the uFlow firmware.</p>
<p dir="auto">I've flashed it several times in fact; with the same end results.</p>
<p dir="auto">The worse part is the super annoying buzz that comes from the speaker; and then after it sitting there powered on for a few hours the cheap adhesive pads they used to attach the screen cover started failing, and the screen cover started lifting at the top.</p>
<p dir="auto">Sorry missed the message above.<br />
Contact M5Stack via email and let them know. It sounds like you have a bad unit.</p>
]]></description><link>https://community.m5stack.com/post/3034</link><guid isPermaLink="true">https://community.m5stack.com/post/3034</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 15 Feb 2019 09:53:34 GMT</pubDate></item><item><title><![CDATA[Reply to Not Connecting to Wifi - First Setup on Fri, 15 Feb 2019 07:11:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> well as I mentioned in the response above the one to you, I had updated the firmware according to the video on the <a href="http://M5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">M5stack.com</a> website; as the only video available that walks you through the process, has you install the uFlow firmware.</p>
]]></description><link>https://community.m5stack.com/post/3033</link><guid isPermaLink="true">https://community.m5stack.com/post/3033</guid><dc:creator><![CDATA[Slumnit]]></dc:creator><pubDate>Fri, 15 Feb 2019 07:11:10 GMT</pubDate></item><item><title><![CDATA[Reply to Not Connecting to Wifi - First Setup on Fri, 15 Feb 2019 06:32:04 GMT]]></title><description><![CDATA[<p dir="auto">have you tried updating the uiflow firmware?</p>
]]></description><link>https://community.m5stack.com/post/3032</link><guid isPermaLink="true">https://community.m5stack.com/post/3032</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 15 Feb 2019 06:32:04 GMT</pubDate></item><item><title><![CDATA[Reply to Not Connecting to Wifi - First Setup on Thu, 14 Feb 2019 22:15:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> I just did what shown here in the video <a href="https://youtu.be/rdz6hBoqamA?t=261" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/rdz6hBoqamA?t=261</a><br />
using the uFlow to add the speaker.beep<br />
Mine doesn't make a short "beep" like in the video, it makes a distorted beep for about 3-5 seconds then reboots.<br />
<a href="https://streamable.com/wgw6v" target="_blank" rel="noopener noreferrer nofollow ugc">https://streamable.com/wgw6v</a></p>
]]></description><link>https://community.m5stack.com/post/3029</link><guid isPermaLink="true">https://community.m5stack.com/post/3029</guid><dc:creator><![CDATA[Slumnit]]></dc:creator><pubDate>Thu, 14 Feb 2019 22:15:49 GMT</pubDate></item><item><title><![CDATA[Reply to Not Connecting to Wifi - First Setup on Thu, 14 Feb 2019 20:36:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a> Nothing is connected; I had just opened it after it was delivered, and then follows some of the video available on <a href="http://M5Stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">M5Stack.com</a> And whatever is the most recent virmware that i downloaded from M5stack instructed by the video on how to upgrade firmware</p>
]]></description><link>https://community.m5stack.com/post/3028</link><guid isPermaLink="true">https://community.m5stack.com/post/3028</guid><dc:creator><![CDATA[Slumnit]]></dc:creator><pubDate>Thu, 14 Feb 2019 20:36:21 GMT</pubDate></item><item><title><![CDATA[Reply to Not Connecting to Wifi - First Setup on Thu, 14 Feb 2019 18:56:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slumnit" aria-label="Profile: slumnit">@<bdi>slumnit</bdi></a> said in <a href="/post/3023">Not Connecting to Wifi - First Setup</a>:</p>
<p dir="auto">So apparently you can not connect to a WiFi network with a Space in the name; since I'm not going to go around and reset all the wifi connected in the 20+ wireless devices in my home, then this M5Stack is useless.</p>
<p dir="auto">Furthermore; after getting it to connect to a hotspot (running off my iPhone) playing a tone: Speaker.beep freq:1600 duration: 200ms (same shown in an example video from <a href="http://M5Stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">M5Stack.com</a>) the device crashes and reboots every time..</p>
<p dir="auto">What is your code that causes this crash?</p>
]]></description><link>https://community.m5stack.com/post/3027</link><guid isPermaLink="true">https://community.m5stack.com/post/3027</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 14 Feb 2019 18:56:15 GMT</pubDate></item><item><title><![CDATA[Reply to Not Connecting to Wifi - First Setup on Thu, 14 Feb 2019 18:38:21 GMT]]></title><description><![CDATA[<p dir="auto">Hi Slumnit, sounds very unusual. Which firmware are you using? and do you have anything connected to the gpio ports of the m5stack?</p>
]]></description><link>https://community.m5stack.com/post/3025</link><guid isPermaLink="true">https://community.m5stack.com/post/3025</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 14 Feb 2019 18:38:21 GMT</pubDate></item><item><title><![CDATA[Reply to Not Connecting to Wifi - First Setup on Thu, 14 Feb 2019 17:18:56 GMT]]></title><description><![CDATA[<p dir="auto">So apparently you can not connect to a WiFi network with a Space in the name; since I'm not going to go around and reset all the wifi connected in the 20+ wireless devices in my home, then this M5Stack is useless.</p>
]]></description><link>https://community.m5stack.com/post/3023</link><guid isPermaLink="true">https://community.m5stack.com/post/3023</guid><dc:creator><![CDATA[Slumnit]]></dc:creator><pubDate>Thu, 14 Feb 2019 17:18:56 GMT</pubDate></item></channel></rss>
