<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Dial : M5Burner can&#x27;t do Burn]]></title><description><![CDATA[<p dir="auto">I have a question about M5Dial.</p>
<p dir="auto">I want to program with M5Dial, so I want to burn UIFlow2.0, but I get an error[Errno 13].</p>
<p dir="auto">Is there anything I can improve?</p>
<p dir="auto">Thank you for watching.</p>
]]></description><link>https://community.m5stack.com/topic/6800/m5dial-m5burner-can-t-do-burn</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 07:40:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6800.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Sep 2024 02:51:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Dial : M5Burner can&#x27;t do Burn on Wed, 18 Sep 2024 02:22:19 GMT]]></title><description><![CDATA[<p dir="auto">Even when connecting the M5Dial to USB while holding the rear boot button, only one COM port is displayed.<br />
It’s unusual if two ports are not displayed, right?</p>
]]></description><link>https://community.m5stack.com/post/26456</link><guid isPermaLink="true">https://community.m5stack.com/post/26456</guid><dc:creator><![CDATA[kawabatapaper]]></dc:creator><pubDate>Wed, 18 Sep 2024 02:22:19 GMT</pubDate></item><item><title><![CDATA[Reply to M5Dial : M5Burner can&#x27;t do Burn on Tue, 17 Sep 2024 07:12:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kawabatapaper" aria-label="Profile: kawabatapaper">@<bdi>kawabatapaper</bdi></a> when you have M5Burner open and you are connecting your M5Dial to usb are there any com ports detected - should be detection of 2 ports shown in top right hand corner for few seconds, first one is "hidden" boot com port used when rear boot button is held</p>
]]></description><link>https://community.m5stack.com/post/26446</link><guid isPermaLink="true">https://community.m5stack.com/post/26446</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Tue, 17 Sep 2024 07:12:14 GMT</pubDate></item><item><title><![CDATA[Reply to M5Dial : M5Burner can&#x27;t do Burn on Tue, 17 Sep 2024 06:41:04 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for your reply.</p>
<p dir="auto">As you two advised, I tried pressing the button on the back while connecting to the USB and burning it, but I got the same error.<br />
I tried cables M5StackCORE2 and M5Station just before and they connected without any problems.</p>
]]></description><link>https://community.m5stack.com/post/26444</link><guid isPermaLink="true">https://community.m5stack.com/post/26444</guid><dc:creator><![CDATA[kawabatapaper]]></dc:creator><pubDate>Tue, 17 Sep 2024 06:41:04 GMT</pubDate></item><item><title><![CDATA[Reply to M5Dial : M5Burner can&#x27;t do Burn on Mon, 16 Sep 2024 10:17:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kawabatapaper" aria-label="Profile: kawabatapaper">@<bdi>kawabatapaper</bdi></a> M5Dial has little button at the back (hard to sense when is pushed in really)<br />
This boot button have to be held pushed in while M5Dial is being connected to usb then let it go when com port detected.</p>
]]></description><link>https://community.m5stack.com/post/26439</link><guid isPermaLink="true">https://community.m5stack.com/post/26439</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 16 Sep 2024 10:17:18 GMT</pubDate></item><item><title><![CDATA[Reply to M5Dial : M5Burner can&#x27;t do Burn on Sun, 15 Sep 2024 07:14:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kawabatapaper" aria-label="Profile: kawabatapaper">@<bdi>kawabatapaper</bdi></a> Have you put the Dial into Bootloader mode in order to enable firmware writing?<br />
Have you checked your cables are good working Power and sync cables?<br />
Have you connected the Dial to the computer?<br />
You haven't provided enough information.</p>
]]></description><link>https://community.m5stack.com/post/26431</link><guid isPermaLink="true">https://community.m5stack.com/post/26431</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 15 Sep 2024 07:14:34 GMT</pubDate></item></channel></rss>
