<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Zehnder MVHR + AtomS3 Lite Help PLEASE]]></title><description><![CDATA[<p dir="auto">Hi, Wondering if somebody would be kind enough to help.<br />
In short, I am new M5Stack and hardware in general.<br />
I have bout AtomS3 Lite and Min Can to use on this project.<br />
<a href="https://github.com/yoziru/esphome-zehnder-comfoair" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/yoziru/esphome-zehnder-comfoair</a></p>
<p dir="auto">However, I am stuck!  I have downloaded M5 Burner, connected and flashed the AtomS3.  It is connected to my wifi... but I am now totally stuck as what to do next.<br />
How to get the files from Github onto the Atom, where they are be stored.</p>
<p dir="auto">Could anybody please give me some pointers?<br />
Thanks<br />
Bill</p>
]]></description><link>https://community.m5stack.com/topic/6833/zehnder-mvhr-atoms3-lite-help-please</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 06:49:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6833.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Sep 2024 20:09:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Zehnder MVHR + AtomS3 Lite Help PLEASE on Fri, 27 Sep 2024 07:09:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hoogagroup" aria-label="Profile: hoogagroup">@<bdi>hoogagroup</bdi></a>  from project description:</p>
<p dir="auto">"Software<br />
Copy and rename secrets.yaml.example to secrets.yaml and update it with your WiFi credentials (wifi_ssid and wifi_password).<br />
Build the image with ESPHome<br />
make compile<br />
Upload/flash the firmware to the board.<br />
make upload<br />
By default the project builds for the AtomS3 board. To change your board, you can specify the BOARD parameter. For example for the Olimex ESP32-EVB:<br />
make compile BOARD=esp32-evb<br />
make upload BOARD=esp32-evb<br />
Now when you go to the Home Assistant “Integrations” screen (under “Configuration” panel), you should see the ESPHome device show up in the discovered section (although this can take up to 5 minutes). Alternatively, you can manually add the device by clicking “CONFIGURE” on the ESPHome integration and entering “&lt;NODE_NAME&gt;.local” as the host."</p>
<p dir="auto">so you need to see ESPHome for it.</p>
]]></description><link>https://community.m5stack.com/post/26522</link><guid isPermaLink="true">https://community.m5stack.com/post/26522</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Fri, 27 Sep 2024 07:09:54 GMT</pubDate></item></channel></rss>
