<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TVOC&#x2F;eCO2 accuracy]]></title><description><![CDATA[<p dir="auto">Hey friends:</p>
<p dir="auto">I made a simple sketch that displays the CO2eq and TVOC values on a display.</p>
<p dir="auto">I have a highly accurate aranet4 to compare to.  I know the sensor in the TVOC/eCO2 is not a true CO2 sensor but was curious if there's a way to adjust it to more closely match the value on the aranet4.</p>
<p dir="auto">I'm going to let it run all night and see if it gets any closer.  Right now here's what I'm seeing:</p>
<p dir="auto">TVOC/eCO2 - 400<br />
aranet4 - 560</p>
<p dir="auto">The sensor seems never to deviate from 400 unless I blow on it.</p>
]]></description><link>https://community.m5stack.com/topic/6838/tvoc-eco2-accuracy</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:48:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6838.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Sep 2024 20:12:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TVOC&#x2F;eCO2 accuracy on Sun, 29 Sep 2024 16:34:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/greenleaf" aria-label="Profile: greenleaf">@<bdi>greenleaf</bdi></a> Can you set up some kind or record to show the reading from both over a long time?<br />
I haven't done a long term test so I'm curious.<br />
If you can map the deviation between the two then you should be able to tune the sensor.<br />
Also some thing else to check is if they are reading at the same resolution.</p>
]]></description><link>https://community.m5stack.com/post/26543</link><guid isPermaLink="true">https://community.m5stack.com/post/26543</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 29 Sep 2024 16:34:22 GMT</pubDate></item><item><title><![CDATA[Reply to TVOC&#x2F;eCO2 accuracy on Sun, 29 Sep 2024 00:11:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/greenleaf" aria-label="Profile: greenleaf">@<bdi>greenleaf</bdi></a></p>
<p dir="auto">Ok so interesting results; after letting the device run all night it did eventually get quite close to the Aranet4 readings for CO2.</p>
]]></description><link>https://community.m5stack.com/post/26536</link><guid isPermaLink="true">https://community.m5stack.com/post/26536</guid><dc:creator><![CDATA[greenleaf]]></dc:creator><pubDate>Sun, 29 Sep 2024 00:11:51 GMT</pubDate></item></channel></rss>
