<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[logic level]]></title><description><![CDATA[<p dir="auto">So I wanted to connect the M5Stick to the CJMCU-8118 module that has 3V3 logic and needs 3V3 for power. I am not sure if I can just use some 3V3 regulator to step down the voltage from M5Stick and connect data lines directly or if I need logic level converter for data lines. I looked at the schematic on github and it looks like the grove pins are connected directly to the mcu.</p>
]]></description><link>https://community.m5stack.com/topic/685/logic-level</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 03:29:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/685.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Feb 2019 08:51:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to logic level on Thu, 21 Mar 2019 09:34:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smrtokvitek" aria-label="Profile: smrtokvitek">@<bdi>smrtokvitek</bdi></a>  just use some 3V3 regulator to step down the voltage from M5Stick and connect data lines directly. As you said, the data pins all connect directly to esp32.</p>
]]></description><link>https://community.m5stack.com/post/3369</link><guid isPermaLink="true">https://community.m5stack.com/post/3369</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Thu, 21 Mar 2019 09:34:57 GMT</pubDate></item></channel></rss>
