<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AtomS3R IMU and magnetometer calibration]]></title><description><![CDATA[<p dir="auto">How can I calibrate AtomS3R IMU and magnetometer? Can someone provide some methods and examples? Maybe in M5Unified?</p>
<p dir="auto">Any example of a compass for it?</p>
<p dir="auto">thanks</p>
]]></description><link>https://community.m5stack.com/topic/6872/atoms3r-imu-and-magnetometer-calibration</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:05:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6872.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Oct 2024 22:40:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AtomS3R IMU and magnetometer calibration on Sun, 09 Feb 2025 04:45:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/patf" aria-label="Profile: patf">@<bdi>patf</bdi></a> said in <a href="/post/26744">AtomS3R IMU and magnetometer calibration</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mgrouch" aria-label="Profile: mgrouch">@<bdi>mgrouch</bdi></a> Hi there, the M5Unified library has a calibration routine that works well. See the IMU example in the library, and make sure to read all of the comments carefully.</p>
<p dir="auto">You press the Atom BtnA (screen) and it will calibrate for 10 seconds, enough to do one axis at a time. You are best to calibrate the accelerometer, gyro and magnetometer separately for best results.</p>
<p dir="auto">Personally I modified the example so that the calibration starts on press BtnA, and ends on the second press of BtnA. i.e. no 10 second countdown. This way I can take my time and calibrate all 3 axes of each sensor (accl, gyro, or mag) in one continuous movement.</p>
<p dir="auto">I looked at the calibration code in m5unified library. It doesn't look right to me.<br />
There is no sphere fit being performed. Only offset biases are estimated.<br />
What about scale biases?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/post/28155</link><guid isPermaLink="true">https://community.m5stack.com/post/28155</guid><dc:creator><![CDATA[mgrouch]]></dc:creator><pubDate>Sun, 09 Feb 2025 04:45:31 GMT</pubDate></item><item><title><![CDATA[Reply to AtomS3R IMU and magnetometer calibration on Tue, 15 Oct 2024 10:10:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mgrouch" aria-label="Profile: mgrouch">@<bdi>mgrouch</bdi></a> Hi there, the M5Unified library has a calibration routine that works well. See the IMU example in the library, and make sure to read all of the comments carefully.</p>
]]></description><link>https://community.m5stack.com/post/26744</link><guid isPermaLink="true">https://community.m5stack.com/post/26744</guid><dc:creator><![CDATA[patf]]></dc:creator><pubDate>Tue, 15 Oct 2024 10:10:00 GMT</pubDate></item></channel></rss>
