<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Offline mode in UIflow (StickC Plus2)]]></title><description><![CDATA[<p dir="auto">I'm new into M5Stack world.<br />
I received the stick with a demo program. So I used M5burner to install UIflow. My first surprise was that M5burner decided to use WiFi instead of ttyACM0 to download the firmware.<br />
Once completed, I used Configure to set StartMode to USB.<br />
I downloaded UIflow-IDE and installed it on Linux host.<br />
I boot the stick and set mode to USB and then I start IUflow-IDE. The status bar display "ttyACM0". After a few seconds the status bar display "Disconnected" in red and a message box show: "Upload code failed, maybe your device is offline ...".</p>
<p dir="auto">Sometimes, on the console, I see:<br />
"[Error: Error Ressource temporarily unavailable. Cannot lock port]<br />
I checked and I have the appropriate privileges to use (r/w) the serial port.</p>
<p dir="auto">Questions:</p>
<li>'offline' in the messageBox. What does it refer to?</li>
<li>Is it possible to use UIflow with WiFi?</li>
<li>How can I fix my problem?</li>
<p dir="auto">Thanks for any help</p>
]]></description><link>https://community.m5stack.com/topic/6875/offline-mode-in-uiflow-stickc-plus2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:12:05 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6875.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Oct 2024 18:55:32 GMT</pubDate><ttl>60</ttl></channel></rss>
