<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New to Atom S3R - Screen stopped working after burning firmware]]></title><description><![CDATA[<p dir="auto">Hello everyone!</p>
<p dir="auto">I'm new to the AtomS3R and just got mine.  It ran the user demo just fine when I applied power, and after getting M5Burner, I tried loading the SNake Game, Hal9000 and a few other firmwares, but each time, the burn was successful, but after unplugging power and plugging it back in, there was nothing on the screen.</p>
<p dir="auto">When I burned each time, I held the power button on the side down while I plugged in the power, and when it blinked green, I stopped holding and hit the burn firmware button.</p>
<p dir="auto">What might I be doing wrong, and what can I do to troubleshoot?</p>
]]></description><link>https://community.m5stack.com/topic/6879/new-to-atom-s3r-screen-stopped-working-after-burning-firmware</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:47:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6879.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Oct 2024 13:19:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New to Atom S3R - Screen stopped working after burning firmware on Fri, 11 Oct 2024 22:17:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Yes.  This time I erased first, and it completed successfully.  I reset it afterwards, then put it into download mode again (flashing green led) and then burned the Atom S3R UIFlow image.  It burned successfully.</p>
<p dir="auto">When I clicked the reset button, it found COM4 and COM5 (it usually just has COM4) but still no screen.</p>
<p dir="auto">Now I think I have it working.  I think maybe I assumed it would load a program to the screen for UIFlow, but I guess it doesn't?</p>
<p dir="auto">Is there a good place to get more S3R programs?  I only see the UIFlow one in M5Burner?</p>
]]></description><link>https://community.m5stack.com/post/26696</link><guid isPermaLink="true">https://community.m5stack.com/post/26696</guid><dc:creator><![CDATA[slooker]]></dc:creator><pubDate>Fri, 11 Oct 2024 22:17:05 GMT</pubDate></item><item><title><![CDATA[Reply to New to Atom S3R - Screen stopped working after burning firmware on Fri, 11 Oct 2024 20:22:58 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/slooker" aria-label="Profile: slooker">@<bdi>slooker</bdi></a></p>
<p dir="auto">hmm, have you tried to erase first?</p>
]]></description><link>https://community.m5stack.com/post/26695</link><guid isPermaLink="true">https://community.m5stack.com/post/26695</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 11 Oct 2024 20:22:58 GMT</pubDate></item><item><title><![CDATA[Reply to New to Atom S3R - Screen stopped working after burning firmware on Fri, 11 Oct 2024 19:41:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> This is the one I've been trying.</p>
<p dir="auto"><img src="/assets/uploads/files/1728573930320-ee64dd95-1737-4f80-93e7-10b40d2f9f97-image.png" alt="ee64dd95-1737-4f80-93e7-10b40d2f9f97-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">UIFlow2.0 AtomS3R</p>
<p dir="auto">It says it's burned successfully, but still nothing after unplugging and replugging.</p>
]]></description><link>https://community.m5stack.com/post/26694</link><guid isPermaLink="true">https://community.m5stack.com/post/26694</guid><dc:creator><![CDATA[slooker]]></dc:creator><pubDate>Fri, 11 Oct 2024 19:41:55 GMT</pubDate></item><item><title><![CDATA[Reply to New to Atom S3R - Screen stopped working after burning firmware on Thu, 10 Oct 2024 04:58:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slooker" aria-label="Profile: slooker">@<bdi>slooker</bdi></a> Does the Firmware say compatible with S3R?<br />
If not then that's why nothing is happening.</p>
]]></description><link>https://community.m5stack.com/post/26677</link><guid isPermaLink="true">https://community.m5stack.com/post/26677</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 10 Oct 2024 04:58:12 GMT</pubDate></item><item><title><![CDATA[Reply to New to Atom S3R - Screen stopped working after burning firmware on Wed, 09 Oct 2024 20:19:30 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/slooker" aria-label="Profile: slooker">@<bdi>slooker</bdi></a></p>
<p dir="auto">my guess is that most (if not all) third-party programs in M5Burner have been made before the 'R' version of M5AtomS3<strong>R</strong> came out.</p>
<p dir="auto">M5AtomS3 and M5AtomS3<strong>R</strong> use slightly different hardware which probably need new versions of these third-party programs.</p>
<p dir="auto">You can see that M5AtomS3 and M5AtomS3<strong>R</strong> are different from the fact that two versions for the official UIFlow2 firmware exist.</p>
<p dir="auto">I suggest you try <em>UIFlow2.0 AtomS3<strong>R</strong></em> firmware to verify the screen is ok.</p>
]]></description><link>https://community.m5stack.com/post/26673</link><guid isPermaLink="true">https://community.m5stack.com/post/26673</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 09 Oct 2024 20:19:30 GMT</pubDate></item></channel></rss>
