<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Lesson 23. M5CAMERA. Introduce]]></title><description><![CDATA[<h3>The purpose of this lesson</h3>
<p dir="auto">Hi! Today we'll meet M5CAMERA (figure 1).</p>
<p dir="auto"><img src="https://pp.userapi.com/c847020/v847020304/1a27ae/0hgOEk7idew.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 1</p>
<p dir="auto">This tutorial will teach you how to use the camera with a web browser.</p>
<h3>Short help</h3>
<li>Purpose: used for video surveillance in real time</li>
<li>Scope: agriculture, science and home life</li>
<li>Connection interface: Wi-Fi, I2C (Groove), PDM, GPIO, USB Type C<br />
Supply voltage: 5 V</li>
<li>Compatibility: any modern web browser as a client</li>
<li>Form factor: LEGO compatible</li>
<h3>Brief overview</h3>
<p dir="auto">M5CAMERA is the original decision to broadcast images in real time, created by a team of developers M5STACK. This device does not need settings and complex software (figure 1.1).</p>
<p dir="auto"><img src="https://pp.userapi.com/c848636/v848636647/132bf2/X98zJrRCtrs.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 1.1</p>
<p dir="auto">The front panel is centered with the camera lens. To the right of the lens there are holes under which there is a power LED. Below, under the lens, is the M5 logo. On the left side panel there is a button to restart the device. On both sides there are LEGO - compatible holes for the bushings for mounting the legs (figure 2).</p>
<p dir="auto"><img src="https://pp.userapi.com/c848624/v848624304/13423c/xfW55KaMiqU.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 2</p>
<p dir="auto">There is a sticker with tips on the front side of the device. On the bottom side panel there are I2C (Groove) and USB Type C connectors one after another. The front panel and the front panel are partially connected by means of slot latches and fixed by screws of size M5 (figure 2.1).</p>
<p dir="auto"><img src="https://pp.userapi.com/c848624/v848624304/134245/b9ClICSq0rs.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 2.1</p>
<p dir="auto">The heart of this device is the ESP32 module from ESPRESSIF. You can additionally purchase and connect motion sensors (I2C), temperature sensors (I2C), microphone (PDM), LEDs (GPIO), battery. The "eye of the device" is an OV2640 camera with a resolution of 2 Megapixels (figure 2.3).</p>
<p dir="auto"><img src="https://pp.userapi.com/c846216/v846216247/1a9a6c/aBs16CWakDw.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 2.3</p>
<p dir="auto">Note: do not attempt to adjust the focus of the camera by rotating the lens, otherwise it will damage the camera loop (figure 3).</p>
<p dir="auto"><img src="https://pp.userapi.com/c846216/v846216247/1a9ae7/KyOsiuO3Te8.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 3</p>
<h2>Let's start!</h2>
<p dir="auto">Connect the camera to a power source (such as a USB cable). Wait for the red power LED to glow. Good. Now use your smartphone / tablet / computer to connect wirelessly to the access point that the camera has created automatically. Go to Settings (figure 4).</p>
<p dir="auto"><img src="https://pp.userapi.com/c848628/v848628682/138524/6enruZZh210.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 4</p>
<p dir="auto">Refer to the wireless Wi-Fi settings section (figure 4.1).</p>
<p dir="auto"><img src="https://pp.userapi.com/c848628/v848628682/138573/ZVIKAajF7ro.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 4.1</p>
<p dir="auto">Your device should find the wireless network <strong>M5Cam-test</strong>. Connect to this network (figure 4.2).</p>
<p dir="auto"><img src="https://pp.userapi.com/c848628/v848628682/13852b/owhowUU_4LE.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 4.2</p>
<p dir="auto">Good! Now open <strong>any new browser</strong> and go to <a href="http://192.168.4.1" title="http://192.168.4.1" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.4.1</a> (figure 5 - 5.2).</p>
<p dir="auto"><img src="https://pp.userapi.com/c845017/v845017682/1c3828/cuoUfYrBd_w.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5</p>
<p dir="auto"><img src="https://pp.userapi.com/c845017/v845017682/1c3821/o4y5wfhW82I.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5.1</p>
<p dir="auto"><img src="https://pp.userapi.com/c845017/v845017682/1c382f/xn2vUNyi80c.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5.2</p>
<h3>Downloads</h3>
<p dir="auto">There is nothing in this tutorial ;)</p>
<h3>Demo</h3>
]]></description><link>https://community.m5stack.com/topic/689/lesson-23-m5camera-introduce</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 10:39:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/689.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Feb 2019 12:29:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Lesson 23. M5CAMERA. Introduce on Tue, 21 Apr 2020 00:00:51 GMT]]></title><description><![CDATA[<p dir="auto">Is there an easy way of connecting it to a wifi router?</p>
]]></description><link>https://community.m5stack.com/post/8275</link><guid isPermaLink="true">https://community.m5stack.com/post/8275</guid><dc:creator><![CDATA[nomad13]]></dc:creator><pubDate>Tue, 21 Apr 2020 00:00:51 GMT</pubDate></item></channel></rss>
