<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[When you add a BugC2 HAT to a project in M5StackC Plus2 and try to load the saved program, it does not load correctly.]]></title><description><![CDATA[<p dir="auto">UIFlow version 1.13.8 BugC2<br />
When you add a BugC2 HAT to a project in M5StackC Plus2 and try to load the saved program, it does not load correctly.</p>
<p dir="auto">In UIFlow version 1, you can create a program by adding BugC2 to the Hat block.</p>
<p dir="auto">In this case, "Create new" works without any problems and you can save the project file, but if you try to reload the saved project file in UIFlow1, it fails to load (no error message is displayed and the program display area in the browser remains in its initial state. In addition, the HAT in the block panel becomes "HAT(1)", but the group "BugC2" is not displayed).</p>
]]></description><link>https://community.m5stack.com/topic/6895/when-you-add-a-bugc2-hat-to-a-project-in-m5stackc-plus2-and-try-to-load-the-saved-program-it-does-not-load-correctly</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 07:42:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6895.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Oct 2024 14:08:47 GMT</pubDate><ttl>60</ttl></channel></rss>
