<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOM Motion, if DC Motor is running- disturbance on Servo I2C Interface]]></title><description><![CDATA[<p dir="auto">Hi to everybody,<br />
as a new user of ATOM Motion I have a problem when running a DC motor (on of the 2 DC Motor interfaces) and havin a servo at one of the servo interfaces (4x I2C Interfaces). As soon as i start the motor, the servo starts to tremble-moves quickly some degrees forward/backward. If i stop the motor, the servo stops trembling. (Even disturbance at the PC screen visible)<br />
I tryed it with different motors, always the same.<br />
I put some catacitor paralle to the motor power supply, servo stops trembling.</p>
<p dir="auto">How can this be, i buy a board, designed to run 2x DC motors and 4x Servo and there is a disturbance between them????</p>
<p dir="auto">Does anybody have the same experiance?</p>
<p dir="auto">Thanks for the information</p>
]]></description><link>https://community.m5stack.com/topic/6905/atom-motion-if-dc-motor-is-running-disturbance-on-servo-i2c-interface</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 12:15:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6905.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Oct 2024 09:09:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOM Motion, if DC Motor is running- disturbance on Servo I2C Interface on Fri, 18 Oct 2024 11:25:23 GMT]]></title><description><![CDATA[<p dir="auto">It might be the PWM that makes problem but often its the brushes in the motor that causes the disturbance (sparks during operation). Test if you still have the problem with a resistor instead of the motor. If the problem is gone with resistor then it's the motor. And YES, this is a EMC issue.<br />
Try some filtering on your DC motor by adding 100nF capacitors on it. That means from DC+ to motor case and from DC- to motor case (known as Y configuration). Very important: As close as possible to the motor with leads as short as possible! Solder them direct on the motor. If this not help add another 100nF between + and - (known as X configuration) and also a inductivity of a few µH in the DC+ and DC- wire (this can be a wire that goes a few times trough a small ferrite torroid).</p>
<p dir="auto">Edit:<br />
"As my teachers always said, EMC is magic......."<br />
-&gt; capacitors and inductors are the magic spells!</p>
]]></description><link>https://community.m5stack.com/post/26776</link><guid isPermaLink="true">https://community.m5stack.com/post/26776</guid><dc:creator><![CDATA[holofloh]]></dc:creator><pubDate>Fri, 18 Oct 2024 11:25:23 GMT</pubDate></item><item><title><![CDATA[Reply to ATOM Motion, if DC Motor is running- disturbance on Servo I2C Interface on Fri, 18 Oct 2024 10:00:46 GMT]]></title><description><![CDATA[<p dir="auto">Seems to be EMC disturbance.<br />
Whenever the DC motor is running, the Servo jumps back and forward , the IT remote control does not work...<br />
Motor stop, everything is fine.</p>
<p dir="auto">So i tried some things and found out:<br />
Usually the DC Moto cable leaves the Atom Motion case in a 90 degree angle. If i bend the cable right after the plug, so that tha cable moves parallel away from the atom motion case, everything is fine.</p>
<p dir="auto">Seems to be a disturbance due to the PWM which disturbes even the power supply. Thats why servo and IR sensor gets crazy.</p>
<p dir="auto">As my teachers always said, EMC is magic.......</p>
<p dir="auto">If you have similar experiance, please answer..</p>
<p dir="auto">thanks<br />
Harry</p>
]]></description><link>https://community.m5stack.com/post/26774</link><guid isPermaLink="true">https://community.m5stack.com/post/26774</guid><dc:creator><![CDATA[HARRY_GO]]></dc:creator><pubDate>Fri, 18 Oct 2024 10:00:46 GMT</pubDate></item></channel></rss>
