<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Burner on MacOs Sequoia 15.1 does not work]]></title><description><![CDATA[<p dir="auto">The MacOS M5Burner is prevented from running due to possible security problem.<br />
It is Intel code but my system is apple chip (M1).</p>
]]></description><link>https://community.m5stack.com/topic/6960/m5burner-on-macos-sequoia-15-1-does-not-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:48:44 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6960.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Nov 2024 00:19:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Burner on MacOs Sequoia 15.1 does not work on Mon, 27 Jan 2025 15:44:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aivarannamaa" aria-label="Profile: aivarannamaa">@<bdi>aivarannamaa</bdi></a><br />
This solved the problem. Thanks!</p>
]]></description><link>https://community.m5stack.com/post/28068</link><guid isPermaLink="true">https://community.m5stack.com/post/28068</guid><dc:creator><![CDATA[haruhisa]]></dc:creator><pubDate>Mon, 27 Jan 2025 15:44:07 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner on MacOs Sequoia 15.1 does not work on Wed, 01 Jan 2025 09:31:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aivarannamaa" aria-label="Profile: aivarannamaa">@<bdi>aivarannamaa</bdi></a> I just ran into this issue, and your advice helped (MBA M2 Sequoia 15.2) – thank you!</p>
]]></description><link>https://community.m5stack.com/post/27675</link><guid isPermaLink="true">https://community.m5stack.com/post/27675</guid><dc:creator><![CDATA[DINK74]]></dc:creator><pubDate>Wed, 01 Jan 2025 09:31:16 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner on MacOs Sequoia 15.1 does not work on Fri, 29 Nov 2024 17:39:17 GMT]]></title><description><![CDATA[<p dir="auto">Run following command in Terminal:</p>
<p dir="auto">xattr -c /Applications/M5Burner.app</p>
<p dir="auto">This will remove the quarantine flags from the app.</p>
]]></description><link>https://community.m5stack.com/post/27232</link><guid isPermaLink="true">https://community.m5stack.com/post/27232</guid><dc:creator><![CDATA[aivarannamaa]]></dc:creator><pubDate>Fri, 29 Nov 2024 17:39:17 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner on MacOs Sequoia 15.1 does not work on Wed, 06 Nov 2024 08:30:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bobkummerfeld" aria-label="Profile: bobkummerfeld">@<bdi>bobkummerfeld</bdi></a> You need to grant permission to M5Burner to run.<br />
Apple changed the security to prevent none App Store apps from running and so you need to manually permit access.</p>
<p dir="auto">The process is a bit confusing so please google how to permit none approved apps from running on Apple M1 based computers.</p>
]]></description><link>https://community.m5stack.com/post/26972</link><guid isPermaLink="true">https://community.m5stack.com/post/26972</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 06 Nov 2024 08:30:02 GMT</pubDate></item></channel></rss>
