<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickPlus2 -  esp_core_dump_flash: Core dump flash config is corrupted!]]></title><description><![CDATA[<p dir="auto">Hi guys, I have a new M5StickPlus2 and probably a bug in the library. When I flash something with the Arduino IDE the flashing is successful but in Console I get the error “esp_core_dump_flash: Core dump flash config is corrupted!” and the stick is stuck in a boot loop. The error only occurs if the library “M5StickCPlus2.h” is included. If I do not include it, I can flash the stick without any problems an the flashed Programm works. I have now tested both available versions of the library but with both I get the same error.<br />
Does anyone have any ideas?</p>
]]></description><link>https://community.m5stack.com/topic/6963/m5stickplus2-esp_core_dump_flash-core-dump-flash-config-is-corrupted</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 18:49:47 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6963.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 06 Nov 2024 17:05:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickPlus2 -  esp_core_dump_flash: Core dump flash config is corrupted! on Fri, 08 Nov 2024 04:20:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/g00th" aria-label="Profile: G00TH">@<bdi>G00TH</bdi></a><br />
I have never encountered this problem, and I don't see any place in M5StickCPlus2.h that may cause this problem. Maybe it is related to Flash Mode? If possible, can you provide your code?</p>
]]></description><link>https://community.m5stack.com/post/26987</link><guid isPermaLink="true">https://community.m5stack.com/post/26987</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Fri, 08 Nov 2024 04:20:38 GMT</pubDate></item></channel></rss>
