<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Core Basic - LoRa V1.1 &amp; Meshtastic Issues]]></title><description><![CDATA[<p dir="auto">Hi All</p>
<p dir="auto">I am stuck and a bit lost,</p>
<p dir="auto">1: M5Stack Core Basic<br />
2: LoRa 868 V1.1 Module</p>
<p dir="auto">I have a Core Basic and downloaded the Meshtastic Firmware from the browser flasher, All boots as it should and says "Critical Fault #3" Which looking up means it ca not see the LoRa Module.</p>
<p dir="auto">Now i have the module connected and it is still saying the same thing when it boots. The firmware seems to be all fine apart from this not seeing the added Module LoRa V1.1</p>
<p dir="auto">The module has pin switches and came with 1 / 5 / 7 switched on but this is where i am lost because i dont know what is right and how the pins should be as there is little information out here.</p>
<p dir="auto">Does anyone know what pin switches need to be set at or am i missing something else i have to do to make the to match up.</p>
<p dir="auto">Thanks in advance<br />
Craig<br />
<img src="/assets/uploads/files/1732023422811-pins.jpg" alt="Pins.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1732023423004-front.jpg" alt="Front.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1732023442539-pins.jpg" alt="Pins.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1732023442561-front.jpg" alt="Front.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/6996/m5stack-core-basic-lora-v1-1-meshtastic-issues</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 04:05:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6996.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Nov 2024 13:37:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Core Basic - LoRa V1.1 &amp; Meshtastic Issues on Fri, 22 Nov 2024 09:12:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m3hbi" aria-label="Profile: M3HBI">@<bdi>M3HBI</bdi></a><br />
have you tried just simply follow the instrument: <a href="https://docs.m5stack.com/en/uiflow/blockly/module/lora868" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/en/uiflow/blockly/module/lora868</a></p>
]]></description><link>https://community.m5stack.com/post/27123</link><guid isPermaLink="true">https://community.m5stack.com/post/27123</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Fri, 22 Nov 2024 09:12:18 GMT</pubDate></item></channel></rss>
