<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LAN Base and module reset]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1550747057368-20190221_115742.jpg" alt="0_1550747053606_20190221_115742.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Hi,<br />
I installed an external capacitor on the battery module to allow the proper reset sequence into the core module.<br />
Ok, now I buyed a LAN module which does not have the output connections, so I solved the problem as in the image.<br />
Thank to the big dimension of the ethernet socket, there is a lot of space to mount a 4,7uF capacitor.</p>
<p dir="auto">Note : that cap was what I already have in my lab.</p>
<p dir="auto">Now everything is ok, but the question is: do you plan to solve this issue in a future release ?<br />
For a massive (industrial) use of your module, a workaround must be done for <em>every</em> module, and this is not acceptable...</p>
<p dir="auto">Regards<br />
Dave</p>
]]></description><link>https://community.m5stack.com/topic/700/lan-base-and-module-reset</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 17:57:57 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/700.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Feb 2019 11:11:58 GMT</pubDate><ttl>60</ttl></channel></rss>
