<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5CoreInk RTC doesn&#x27;t wakeup when connected to USB]]></title><description><![CDATA[<p dir="auto">I have a modified version of the RTC_Clock example and it doesn't wakeup after an M5.shutdown(55) when it is connected to USB. If I disconnect the USB cable, the sketch works.</p>
<p dir="auto">The same behavior when I use the unmodified example. The RTC_Wakeup example also exhibits the same behavior.</p>
<p dir="auto">This makes it impossible to use Serial.print debug statements.</p>
<p dir="auto">Happy to include my modified sketch when I have the privileges to do so.</p>
]]></description><link>https://community.m5stack.com/topic/7001/m5coreink-rtc-doesn-t-wakeup-when-connected-to-usb</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 18:42:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7001.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Nov 2024 14:11:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5CoreInk RTC doesn&#x27;t wakeup when connected to USB on Thu, 21 Nov 2024 21:43:38 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/bsmorgan" aria-label="Profile: bsmorgan">@<bdi>bsmorgan</bdi></a></p>
<p dir="auto">well, M5CoreInk cannot shutdown in the first place when running from USB - see schematic <a href="https://docs.m5stack.com/en/core/coreink?id=schematic" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">A modified USB-C cable (with 5 V line cut) might help with debug statements in this case.</p>
]]></description><link>https://community.m5stack.com/post/27120</link><guid isPermaLink="true">https://community.m5stack.com/post/27120</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 21 Nov 2024 21:43:38 GMT</pubDate></item></channel></rss>
