<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[JoyC missing documentation]]></title><description><![CDATA[<p dir="auto">I miss some descriptions and/or a schematic, to understand details of JoyC:</p>
<li>
<p dir="auto">Which pins from the StickC are used by the JoyC, which are available for other purposes?<br />
(I guess only 2 pins are used for SDA/SCL, so one should be available)</p>
</li>
<li>
<p dir="auto">Also, i wonder what the Battery on JoyC does. Does it power the stick, or does it only drive the JoyC?</p>
</li>
<li>
<p dir="auto">What is the switch doing?<br />
I can see that the led's are turned on and off, but does it also have other effects?</p>
</li>
]]></description><link>https://community.m5stack.com/topic/7006/joyc-missing-documentation</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 22:32:57 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7006.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 23 Nov 2024 09:13:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to JoyC missing documentation on Fri, 29 Nov 2024 10:33:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sirtet" aria-label="Profile: sirtet">@<bdi>sirtet</bdi></a></p>
<li>
<p dir="auto">I think there is a switch pin in addition to SDA and SCL (the joystick is pressed or not)</p>
</li>
<li>
<p dir="auto">The battery can power the Stick, and StickC and StickCPlus can read the battery voltage, but StickCPlus2 cannot</p>
</li>
<li>
<p dir="auto">I personally adopt that the switch could just powering the LEDs...or STM32 on JoyC?</p>
</li>
]]></description><link>https://community.m5stack.com/post/27224</link><guid isPermaLink="true">https://community.m5stack.com/post/27224</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Fri, 29 Nov 2024 10:33:31 GMT</pubDate></item></channel></rss>
