<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Fire psram setup woes]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/701/can-t-get-new-m5-fire-to-setup">Can't get new M5 FIRE to setup</a></p>
<p dir="auto">I found the M5Burner tool and tried some different firmwares. Really, just guessing. I tried M5Fire-v.16-psram, since that's most applicable to my device, but the end result was the same.</p>
<p dir="auto">Eventually, I found M5Cloud-v-0.4.0 which does work. However, that only lets me code in Python, which is not what I want. But I guess I know I have a working device. If only I was in 3rd grade Python class, and not trying to run my ESP3266 data logger that I wrote in C.</p>
]]></description><link>https://community.m5stack.com/topic/703/m5-fire-psram-setup-woes</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 11:17:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/703.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Feb 2019 17:14:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Fire psram setup woes on Thu, 21 Feb 2019 17:42:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mikey-wetzel" aria-label="Profile: mikey-wetzel">@<bdi>mikey-wetzel</bdi></a> You can program in C using the espressif or Arduino but you will need to create your own wifi connect routines</p>
]]></description><link>https://community.m5stack.com/post/3116</link><guid isPermaLink="true">https://community.m5stack.com/post/3116</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 21 Feb 2019 17:42:58 GMT</pubDate></item></channel></rss>
