<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t connect to device in UI FLOW2 on atomS3U]]></title><description><![CDATA[<p dir="auto">I was able to load a program with arduino ide,I then flashed UIFLOW2 on it but I get this error no matter what I try : NotFoundError: Failed to execute 'requestPort' on 'Serial': No port selected by the user.</p>
]]></description><link>https://community.m5stack.com/topic/7044/can-t-connect-to-device-in-ui-flow2-on-atoms3u</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 13:34:25 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7044.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Dec 2024 21:15:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t connect to device in UI FLOW2 on atomS3U on Tue, 03 Dec 2024 05:47:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bzh2ant2" aria-label="Profile: Bzh2ant2">@<bdi>Bzh2ant2</bdi></a> Did you erase first?<br />
Did you hold the boot mode button before erasing and burning firmware?</p>
]]></description><link>https://community.m5stack.com/post/27318</link><guid isPermaLink="true">https://community.m5stack.com/post/27318</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 03 Dec 2024 05:47:04 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t connect to device in UI FLOW2 on atomS3U on Mon, 02 Dec 2024 09:03:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bzh2ant2" aria-label="Profile: Bzh2ant2">@<bdi>Bzh2ant2</bdi></a> is M5burner detecting any comport while your device is connected to usb?</p>
]]></description><link>https://community.m5stack.com/post/27297</link><guid isPermaLink="true">https://community.m5stack.com/post/27297</guid><dc:creator><![CDATA[robski]]></dc:creator><pubDate>Mon, 02 Dec 2024 09:03:40 GMT</pubDate></item></channel></rss>
