<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Burner cannot publish BIN file due to DBus error]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I am trying to publish a firmware .bin file with M5Burner. The problem is that the + buttons to select the .bin file or the cover illustration do not respond.</p>
<p dir="auto">In the terminal, I get this error message.<br />
[16551:1207/221226.940000:ERROR:select_file_dialog_impl_portal.cc(698)] Portal returned error: org.freedesktop.DBus.Error.AccessDenied: Portal operation not allowed: Unable to open /proc/16551/root</p>
<p dir="auto">It seems to be trying to open a connection to another process but cannot access procfs as non-root. I tried running M5Burner as sudo but it won't start because of a security restriction apparently in Chromium:<br />
[1207/223917.916497:FATAL:electron_main_delegate.cc(290)] Running as root without --no-sandbox is not supported. See <a href="https://crbug.com/638180" target="_blank" rel="noopener noreferrer nofollow ugc">https://crbug.com/638180</a>.</p>
<p dir="auto">This is running on Linux Mint 22 Cinnamon (amd64), based on Ubuntu Noble.</p>
<p dir="auto">Any suggestions?<br />
Thanks<br />
--Louis</p>
]]></description><link>https://community.m5stack.com/topic/7062/m5burner-cannot-publish-bin-file-due-to-dbus-error</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 10:04:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7062.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Dec 2024 03:59:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Burner cannot publish BIN file due to DBus error on Fri, 18 Apr 2025 06:29:32 GMT]]></title><description><![CDATA[<p dir="auto">The M5Burner DBus error when publishing a BIN file usually indicates a permissions or communication issue between the app and system services. To fix it, try running M5Burner as administrator (or with sudo on Linux), ensure DBus is properly installed, and check USB device access permissions on your system.</p>
]]></description><link>https://community.m5stack.com/post/28924</link><guid isPermaLink="true">https://community.m5stack.com/post/28924</guid><dc:creator><![CDATA[peolsolutions]]></dc:creator><pubDate>Fri, 18 Apr 2025 06:29:32 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner cannot publish BIN file due to DBus error on Fri, 21 Feb 2025 07:48:16 GMT]]></title><description><![CDATA[<p dir="auto">An M5Burner DBus error may occur when publishing a BIN file due to permission issues, missing dependencies, or port conflicts. Ensure there is no other application using the same serial port and run M5Burner as an administrator, restart the DBus service, and ensure M5Burner is running as an administrator. Reinstall M5Burner, update dependencies and ensure that the USB cable or port is not faulty if the issue persists.</p>
]]></description><link>https://community.m5stack.com/post/28291</link><guid isPermaLink="true">https://community.m5stack.com/post/28291</guid><dc:creator><![CDATA[peolsolutions]]></dc:creator><pubDate>Fri, 21 Feb 2025 07:48:16 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner cannot publish BIN file due to DBus error on Tue, 21 Jan 2025 03:59:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kuriko" aria-label="Profile: kuriko">@<bdi>kuriko</bdi></a> No, that didn't work.<br />
I don't think it's worth pursuing further. It<br />
seems to be a problem with Chromium. M5burner version 202501081800 works fine for me now.<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/post/27963</link><guid isPermaLink="true">https://community.m5stack.com/post/27963</guid><dc:creator><![CDATA[LBertrand]]></dc:creator><pubDate>Tue, 21 Jan 2025 03:59:06 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner cannot publish BIN file due to DBus error on Thu, 26 Dec 2024 08:57:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lbertrand" aria-label="Profile: LBertrand">@<bdi>LBertrand</bdi></a><br />
have you tried sudo --no-sandbox ./M5Burner ?</p>
]]></description><link>https://community.m5stack.com/post/27576</link><guid isPermaLink="true">https://community.m5stack.com/post/27576</guid><dc:creator><![CDATA[kuriko]]></dc:creator><pubDate>Thu, 26 Dec 2024 08:57:41 GMT</pubDate></item></channel></rss>
